Homemade Onboard CO2 Tank, where to get regulator
Discussion in 'The Garage' started by mrk5, Jun 25, 2004.
  1. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    Looking for the 150psi static regulator.
    I did a search of some old posts, and the website for the balloon place everyone recommended isn't working.
    Any more places to get one. The local welding supply place seems to be having trouble finding one.
  2. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    PAINTBALL EQUIPMENT!
  3. sickquad
    sickquad 1/2 ton status
    Jul 23, 2003
    785
    Ma
    McMaster.com has every piece of hardware and shop supply equipment you can imagine. If not try MSCDirect.com
    -Chris
  4. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    Thanks for the suggestions guys, I'll check them out. /forums/images/graemlins/waytogo.gif
  5. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    Where did you get your tank? Did you do much shopping around for deals?
  6. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    I can get a 20lbs tank from the local welding shop for $134 which includes first fill.
    There's an outfit on e-bay that sells 20lb tanks for $89, but with shipping and then filling it comes out to the same. And I would rather support local business.
    Did just find a regulator from Outback Air for $55 includes the quick disconnect for air hose.
  7. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I just finished making mine and I used a 10lb tank with a co2 regulator from the welding shop but I wanted a adjustible one so that I can turn down the psi to use with my welder and it was 60 bucks.
  8. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    So, maybe if I have patience with the welding shop they'll come up with something good then.
  9. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
