Homemade powertank
Discussion in 'The Garage' started by uberbeans, Aug 1, 2006.
  1. uberbeans
    uberbeans 1/2 ton status
    May 14, 2004
    564
    Jacksonville, Florida
    I am interested in converting a scuba tank for the purpose of storing co2 for airing tires up and down. I don't know much about the different fittings and all the other details. I am sure it isn't as simple as just adding co2. There is the problem of adapting fitting for servicing just for starters. Has anyone done this?
  2. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Search, it's been covered here.
    What I recall is that you're better off starting with the right tank as NONE of the fittings are the same. I also suspect that getting such a tank filled may be a challenge.
  3. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    99% of filling places wont work on a tank if its not being filled with the spec gas that it is made for. get the correct one its safer and cheeper in the long run .
  4. bluehen
    bluehen 1/2 ton status
    Nov 11, 2004
    215
    DE
    Do some searching and you'll find a good bit of info.
    I made my own kit, and use it all the time. Works great!
    I got a 20lb tank from a beer distributor, the static regulator from Powertank, and all the hose and fittings from the hardware store. I get my local fire extinguisher servicing company to refill the tanks and they even sold me a fire ext. mounting bracket that I mounted to the inner wheel well. I mounted it with wingnuts in case I need the space.
