Homemade shackle flip
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 674x4, Oct 10, 2001.
  1. 674x4
    674x4 Registered Member
    Jul 30, 2001
    84
    Sour Lake, Texas
    I am going to be doing this to my truck this weeked( 72 frame, 1/2 ton, short step). Any advice? Thanks
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    did you check out the <a target="_blank" href=http://coloradok5.com/shackleflip.shtml>shackel flip</a> write up on tech section?? I'll be doing the same, eventually.
    ARQ.
    offroad baja!!!
    1-72 4x4 CST Blazer
    2-71 4x4 CST Blazer
    <a target="_blank" href=http://coloradok5.com/gallery/ArqDennis>My Pics</a>
  3. 674x4
    Jul 30, 2001
    84
    Sour Lake, Texas
    Yeh I was just wondering if anybody had some more input.
  4. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Seen good jobs and bad jobs.
    Just make sure you cut enough to clear the shackle through it's full travel. I knew one guy that had it on his truck and the shackle rode against the hanger all the time until he hit a bump [​IMG]
    Still Poundin' "pavment" after all these years!!! [​IMG]
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I found that if you score into the frame with a grinding wheel you can use a sawzall to finish the cut! I did one side completely with a grinder. It was getting late, I wanted to finish the other side and my last grinding wheel was just about a nub. I was able to brake a groove thru the hanger in four spots and used my sawzall to cut the rest. It was a snap and saved alot of time!
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  6. Rockjunkies
    Rockjunkies 1/2 ton status
    Jul 26, 2001
    385
    Oklahoma
    I also did mine with a die grinder and sawzall. Even a dremel will work, but you will go through alot of the little disc's. I have a eletric die grinder with a straight head on it that I think that would do all with a 3" cutting wheel. Also, after I did mine, I found that the shackles hit the mounts on full compresion, I didn't trim enough. So, instead of cutting the hole larger, I simply notched the shackles where they were hitting a 1/4" . I think that it should be plenty stout, never had any problems out of them. But I would recomend that you check your pinion angle when you are done. Mine ended up pointing inline with the driveshaft, not good.
    Keep it simple <a target="_blank" href=http://coloradok5.com/gallery/album71>http://coloradok5.com/gallery/album71</a>
  7. 674x4
    Jul 30, 2001
    84
    Sour Lake, Texas
    nobody used a cutting torch?
  8. Rockjunkies
    Jul 26, 2001
    385
    Oklahoma
    I would have if I had one. But be carefull around that tank.
  9. 674x4
    Jul 30, 2001
    84
    Sour Lake, Texas
    no tank, its in the cab. Probably gonna do this tomorrow night, while i'm putting an 8in lift on. HELL YEAH
  10. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    I'm going to do the home shackle flip...
    Does anyone have better pictures than what's on the tech article... It's not too clear...
    I dont know how much to cut out...
  11. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I used a plasma cutter with no problem. Cut through it like butter.
    <a target="_blank" href=http://www.geocities.com/outlaw613/K5.html>http://www.geocities.com/outlaw613/K5.html</a>
  12. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    I used a torch. Cut out enough so the shackle swings freely.
    Sherman, Tx
    <font color=red>The blazer's almost on the road....anyone got tree fiddy?</font color=red>
  13. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
    Check these out <a target="_blank" href=http://community.webshots.com/album/10685237kdEYAEtMcv>http://community.webshots.com/album/10685237kdEYAEtMcv</a> they're what I used as a guide. Thanks <font color=red>Jimmyjack</font color=red>[​IMG]
    -Aaron
    ___ __ _ _ ____ __
    AGM73k5 -- ajgm1@yahoo.com
