homemade shackle flip
Discussion in 'OffRoad Design' started by silver 90, Dec 18, 2000.
  1. silver 90
    silver 90 Registered Member
    Dec 4, 2000
    14
    Nebraska
    I have a question for you, Stephen. Have you read the article about the homemade shackle flip in the technical section of this website? If you haven't, some guy just cut a hole in the bottom of his spring hanger and flipped his stock shackle upside-down. Now obviously this is going to weaken the hanger a little but do you think it would be dangerous to do this? Also, how come you guys don't make a 2" shackle flip for 88-up Chevy's? I apologize if you have answered these questions in the past as I am relatively new to this forum. Thanks.
  2. I've done the same thing on my 3/4 ton truck. It raises the rear the same amount as the length of the shackle. I cut as much as I could out of the bottom of the shackle for clearance, and have had NO problems. Took me a couple hours to do, and cost me nothing. I wouldnt recommend this mod for jumping and high speed offroading, but for mud and rockcrawling it's great.
    You can see my truck at http://home.earthlink.net/~philnsyrep
    Good luck.
  3. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    I did something similar to my Blazer since I couldn't afford the ORD setup. Eventually when I have money, I'll probably buy the offroad designs equipment for the following reasons: It's more stable, more thought out, and actually moves the shackle angle to where it should be. I really don't think ORD would answer a post like this...it's a little rude to ask a company that sells a product with as much time and effort into it like they do to give away the company secrets. Or endorse a homeade job. Ethically and Legally, that could be detrimental to their business. So here's how I see it: the homeade shackle flip is a good solution as a get by tactic, just not optimum by any means. For low speed crawling it might do great but at high speeds in the whoops it might fold up. Personally I believe my next rear suspension will be a 4 link system, but I'm going to get the beast at least running first!!!
    Bryan
    Durant, Ok
  4. Josh
    Josh Registered Member
    Dec 11, 2000
    75
    Glendale, AZ
    Did ORD ever make a front end kit or is it just rear??
  5. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Just rear.
    89 K5 Silverado
    <A target="_blank" HREF=http://mudfrog.coloradok5.com>http://mudfrog.coloradok5.com</A>
  6. silver 90
    Dec 4, 2000
    14
    Nebraska
    Yeah, I kinda figured I wouldn't get an answer from ORD, but I was just curious. I appreciate all the input, guys. I may try it just to see how it looks. When you guys flipped the shackles around, did you happen to notice if it moved the axle forward at all?
    BTW, I didn't mean to be rude to ORD.
    <P ID="edit"><FONT SIZE=-1>Edited by silver 90 on 12/27/00 09:48 PM (server time).</FONT></P>
  7. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    I actually didn't mean to not answer this one, but it's very similar to one I answered, maybe on the main page?....
    You might try searching for it. Basic jist is I really don't endorse cutting the bottom out. The can fold up, and I know it works for some, but I there's just too many variable in how you cut it to say much about it.
    SW-ORD
  8. silver 90
    Dec 4, 2000
    14
    Nebraska
    Thanks Stephen, I figured you had already answered this type of question but I was curious about the strength of the bracket after it has been cut. I don't want mine folding up on me!
  9. laketex
    6,220
    North Texas
    silver, I'll send you a pic of my flip.
    Durant, Ok
  10. silver 90
    Dec 4, 2000
    14
    Nebraska
