homemade shackle flips
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by baldk5, Nov 13, 2001.
  1. baldk5
    baldk5 Registered Member
    Jun 3, 2001
    29
    nova scotia, Canada
    the rear springs on my 90 are sagging bad, and i want to chuck the lift blocks(4"). a while ago i seen a set up for a shackle flip using the front spring hanger from the rear of a chev truck.can anyone give me more info on this set up? is it worth the effort(i dont wheel as often as i should) what kind of a ride can i expect? thx, oh yea i'm gonna buy some new .
    so many parts, never enough money
  2. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    Blue_Beast (AKA Jason hughes) did this to the rear of his Blazer. I had a chance to look at it and I was impressed! It looked factory! Send him a private message or something...I'm sure he'd be happy to answer your questions for you[​IMG]
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  3. Thumper
    Thumper 1/2 ton status
    1,582
    Alberta Canada
    I did the same thing to mine. It was very easy to do. The ride didnt change noticeably, but the fact that the rear blocks are gone is a big improvement. I dont have any good pics of mine, but as Rene said, Blue_Beast has some good ones.
    Mike
    <font color=blue>Thumper
    85 Fullsize Jimmy
    <font color=red>Aint Skeered!! </font color=red>
  4. Confederate9
    Confederate9 1/2 ton status
    May 29, 2000
    1,686
    Greensboro NC
    wait, how is this done? im interested
    <font color=red>K5: Because size DOES matter</font color=red>
    85 K5 4IN LIFT 35 GOOD YEAR WRANGLER MT/R, AMERICAN RACING WHEELS
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    i CUT THE BOTTOMS OUT OF MY SHACKLE HANGERS (oops) but I think eventually I will swap to the front hanger in the rear set up instead. It's a little beefier and doesn't look too complicated.
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I personally think that what jimmyjack did is suicide. I might catch flak from that, but I would not do it. Bad idea in my opinion.
    A front spring hanger from the rear of a 2wd and a lowering shackle for a 2wd truck from JC Whitney works real well and costs about $50.
    Tim
  7. Thumper
    1,582
    Alberta Canada
    You have to find a pickup frame... then you cut off the rear leaf spring front hanger rivets and remove the hangers. Cut your stock Blazer rear leaf spring rear hangers off and bolt the pickup one on. Its a piece of cake to do, although you will prob have to remove your gas tank to do it.
    I can try to scrape up some pics of it, but no promises...
    Mike
    85 Fullsize Jimmy
  8. jimmyjack
    May 11, 2000
    2,290
    Tucson Az
    No flak from me bro! I've had no problems with it what so ever tho. But it doesn't mean the next guy won't. The guy that threw me the idea runs 35" tires and tows a trailer full of quads with his and it's almost been 5 years since he did his. I agree there's not a whole lot of meat when the cutting is done and I get a little nervous out in the boonies when i'm wrapping the axles up, but I get home every time. Like I said tho, for my piece of mind I will eventually go with the other set up. Just a bone for you guys installing the "new" shackle hangers..... instead of removing the gas tank, tie a piece of fishing line to the bolt and pull it thru the frame. This is how I installed my receiver hitch. It makes it a breeze!
    Jim
  9. jason, here is a pic of mine. i got your PM and responded to it. let me know if you have more questions
    <a target="_blank" href=http://www.imagestation.com/mypictures/inbox/view.html?id=4267528619&amp;url=http%3A%2F%2Fwww.imagestation.com%2Fpicture%2Fp71d0bf96df746c652cbefa469bd806f7%2Ffe5d51ab.jpg&amp;caption=shackle%20flip>http://www.imagestation.com/mypictures/inbox/view.html?id=4267528619&amp;url=http%3A%2F%2Fwww.imagestation.com%2Fpicture%2Fp71d0bf96df746c652cbefa469bd806f7%2Ffe5d51ab.jpg&amp;caption=shackle%20flip</a>
    <font color=blue> Experience enables you to recognize a mistake when you make it again.
    </font color=blue>
  10. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Hey Blue_Beast, that's exactly what I'd like to do to mine. Does that hanger fit the stock holes in the frame or did you have to drill new ones? Also what kind of truck did you get the hanger from? How many inches of lift did you get? Did you have to extend driveline or lower the T-case?
    Thanks.
    <font color=purple>//////
    <a target="_blank" href=http://blazer79.freeyellow.com>blazer79.freeyellow.com</a></font color=purple><font color=black>
    Soon a 454 K5!!</font color=black>
  11. you have to drill new holes and cut the bracket down. i got it off an 81 4wd shortbed. got 4 inches and had to shim the pinion back down. best thing to do when looking for a spring hanger is take lots of measurements so you know it's going to work. 4wd 1/2 and 3/4 ton trucks seems to be the hot ticket for these brackets. the spring eye should be 4 inches below the the bottom of the frame and the hanger should place the spring outboard of the frame the same distance as the ones on your blazer. happy grinding![​IMG]
    </font color=blue>
  12. Blazer79
    1,816
    Thanks! [​IMG] I'll start looking for the hanger now.
  13. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    Blue Beast,
    Does this kind of shackle flip push the front axle forward a little like ORD flip brackets? Or does it keep the axle in the same position as the stock set-up?
    74 Blazer
    Zepplin
    Check out my Blazer
    <a target="_blank" href=http://community.webshots.com/user/zepplin1976>http://community.webshots.com/user/zepplin1976</a>
  14. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    In the process of doing mine now.[​IMG] I am cutting the bottom of the hanger and will be welding in some bracing to the top.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  15. well, yes and no. the only thing that will really move the axle forward is one of those blocks with offset centering pins. technically though, as the spring moves down it moves in a arc and therefore does move forward. i could not tell a difference though. i have 4 inches lift and 35s and have to tire interfierence at all. i did cheet my brackets forward 3/4 inch to keep my shackle angle where i wanted it.
    it's amazing how much interest shackle flips get. i think they are a great way to lift the rear. the methode i used is cheep but requires more labor (grinding off 2 sets of brackets instead of one) i think i have just as strong of a set up as the ORD. i'm not knocking them and would gladly use there stuff. this is just a cheeper rout. if you don't want to fuss with more grinding and measuring than go with the ORD. so i guess what i'm saying is, well, i'm cheep and like to do more work than i have to. [​IMG]
    </font color=blue>
