Homemade spanner socket? Upper ball joint adjuster wont back out
Discussion in 'The Garage' started by jjlaughner, Aug 22, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Tried PB Blaster and a punch but couldn't back it out. Does it go in clockwise and backout counter clockwise? (normal right hand thread) or is it backward?
    Anyhow I thought a while back I read something about using a socket and cutting it down.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    It is a righthand thread. Counter clockwise to remove. You can buy the spanner socket for $15.00 from your local Snap-on dealer. /forums/images/graemlins/thumb.gif
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Did you already take the knuckle off? If not then knock out the knuckle. This will make it alot easier to remove the adjuster nut. I couldn't get mine out (with the special socket) with 1/2" ratchet because I didn't know the knuckle would come out with it in (fit time) I used an impact and the special socket to get it out with the knuckle on. With the knuckle out it was easy.
    I was unaware that the knuckle could be removed with the adjuster still in.
    Harley
  4. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    I just went through this with my buddies 10 bolt. I have the Snap on socket. I had the knukle off and STILL couldn't get the sleeve to turn out!! Finally got the torches out, /forums/images/graemlins/weld.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/weld.gifand it came out in pieces!! Stubborn S.O.B.!
  5. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    yeah me too /forums/images/graemlins/confused.gif
    Looks like it threads on the ball joint and the top ear. /forums/images/graemlins/thinking.gif
  6. Hossbaby50
    Sep 1, 2001
    8,972
    Peoria, AZ
    It threads into the knuckle itself not the balljoint. It is threaded backward of what you normally think of. The nut is threaded on the outside and smooth on the inside. Remove the nuts on the ball joints then take a ball joint sperater and a BFH and seperate them. Then try and remove the adjustor.
    Harley
  7. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Will do /forums/images/graemlins/waytogo.gif
  8. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    When I did mine I first removed the knuckle, then back the sleeve almost all of the way out, then turned it back in all of the way and through the bottom of the ear to clean the threads out good.
  9. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    [/ QUOTE ] Use a 13/16 deep socket. Just mark the cuts with a felt pen and have at it with a grinder. /forums/images/graemlins/thumb.gif
  10. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Actually I done that with a 3/4 deep socket today and it didn't help, still can't get the knuckle off.
  11. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i took my knuckles off with no spanner removal and no pickle fork. it was a bitch but they cam out. i was changing ball joints so i didn't care if i buggered the threads up or not.
  12. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Yeah I'm about to the point where its going to get beat out! /forums/images/graemlins/whistling.gif
    might use the torch and warm it up a bit /forums/images/graemlins/weld.gif
  13. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    Dude, you really should pull the knuckle first. That nut has a split in it and when the ball joint is in there, its forcing the nut to expand into the threads, whick would hold it pretty tight I suppose. Mr pickle fork will be your friend here. /forums/images/graemlins/thumb.gif
