Hood braces
Discussion in 'The Garage' started by Muddytazz, May 2, 2004.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Who has a hood brace installed in their rig? I'm looking for pics of some....all views, so I can get an idea of size, thickness, the works. Cause I've seen them not installed in magazines and catalogs but it doesn't give any good ideas as heftiness. Cause another thing i've noticed is where these so called braces go, the hood is contoured /forums/images/graemlins/thinking.gif So does anyone have these installed?
  2. dremu
    Feb 27, 2000
    15,967
    459
    East of San Francisco
    I've used the LMC kit on one or two trucks... I guess it helps, as it keeps the hood from compressing longitudinally. It's certainly not what I'd consider stout, but it's relatively inexpensive and great for the newbie.
    On my Chalet, after bending the hood (doh!) I figgered I could do it myself.
    I bend it back and it looked like above. I ended up taking the hood off and standing on it on it to bend it back. Stronger measures were called for to reinforce it: some ~1" angle iron.
    However, as I discovered, the vertical part of the angle iron is awfully close to the battery terminals, and I had a small electrical incident at BB03 because of that! /forums/images/graemlins/yikes.gif
    Lesson to be learned: Angle iron is OK, but grind down the vertical part at the front end!
    (And sometimes I wonder why I take so many damn pictures... now I know! /forums/images/graemlins/smile.gif)
    OBTW, remember, all, to lube your hood hinges every time you change your oil, or your hood will look like Koala's! /forums/images/graemlins/waytogo.gif
    -- A
  3. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    how did you contend with that 1/4" contour along that rail on the hood? Or did you just leave it gapped?
  4. dremu
    Feb 27, 2000
    15,967
    459
    You mean on the outside edge?, i.e. to the right in the third picture? Donno if I follow.
    I just sheet metal screwed the thing to the lowest part (thus the electrical incident /forums/images/graemlins/blush.gif ) ... basically I modelled it on the LMC kit, but this was cheaper and the parts were local.
    -- A
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    In the 3rd pic, between the 1st and 2nd screws from the hinge, there is that contour of the hood.
  6. dremu
    Feb 27, 2000
    15,967
    459
    Now that you mention it, that sounds familiar... that hood is pretty tweaked, so I may have overdone it with the brace (but dammit, it won't bend again!)
    I don't remember the kit from LMC being curved at all though, it was flat, like... maybe I just used longer screws and didn't tighten them down all the way in those positions.
    The brown truck is 70 miles away or I'd go look at it. /forums/images/graemlins/frown.gif
    -- A
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Thanks for the info Aaron /forums/images/graemlins/thumb.gif
    Anyone else have anything?
  8. 1-ton
    Apr 17, 2004
    2,884
    165
    Las Vegas, Nevada
    About 20 years ago I did the same thing, on one of my trucks, by using angle iron to build my own hood supports, and the same exact thing happened with the battery. After installing the home made hood supports, I started to close the hood, when it made contact with the battery terminals, and it set off some fire works, so I had to cut them back a little more to clear the battery terminals.
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I wouldn't stiffen the hood too much. The reason it is weaker in the middle is to keep it from taking your head off in a front end crash. Make sure whatever you reinforce it with will still bend if you hit an object.
  10. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I totally agree with that and have already thought of that....i am just tired of folding completely good hoods in half just by closing them....folded my 3rd on in half over the weekend and my hinges are damn near new /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Ok, cool, just making sure you weren't going with the, "Bigger is better" mentality like I usually do when I fix stuff. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  12. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    My first thought was to use 1.5" c-channel to stradle that rail on the hood, till i got to thinking /forums/images/graemlins/doah.gif
  13. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    Why not moderize the hinge mechanism? The way I see it is that the springs are the reason for all the stress on the hood. If you take the springs off and incorporate a couple of lift shocks then not only will it be easier to close but the hood will raise by itself. I haven't done it to my 78 truck yet, but I've looked at it and it seems doable.
  14. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    You must live in a stable climate. Here in PA there is not 1 vehicle over 4 years old with working lift shocks. My pop in laws lincoln is notorious for blowing through those damn things. We gave up and use sticks to hold the trunk/hood up. I like the type of springs on my 86 blazer. I folded a brand spanking new hood the first time I closed it on my 79. The springs are just too damn heavy.
  15. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Step 1: Keep those hinges lubed! /forums/images/graemlins/wink.gif
    Step 2: Do NOT just jump up and hang from the front edge of your hood to close it. /forums/images/graemlins/yikes.gif
    Step 3: DO sorta push the hood back towards the windshield as you gently start to pull it closed.
    Step 4: Do NOT accellerate the closing process until after you feel the hinge go past its detent at about mid-travel.
    I've been driving these old junkers for the last 20 years and have never kinked a hood on any of them. /forums/images/graemlins/thumb.gif
    And yeah, look closely at how the hood is designed. It is narrower than the A-pillars, so in a frontal crash it can shoot straight through the windshield and take your head off in less than a heartbeat. That kink-prone area was designed into the hood so that the hood would fold up instead of becoming a giant knife blade... /forums/images/graemlins/yikes.gif
  16. backyardbuilt
    backyardbuilt 1/2 ton status
    May 28, 2002
    1,301
    Olathe, Kansas
    My hinges work great but some idiot closed my hood for me and bent the hood with the lmc braces installed. Right at that contour spot that your talking about. They are cheap from lmc cause they are cheap (IMO). I'm looking into the lift struts got a couple for free and gonna try them might use a prop rod without the springs first though easier.
  17. chevyfumes
    chevyfumes Court jester
    Feb 24, 2000
    38,584
    266
    Watch for the muzzleflash!
    I was thinking about going with a fiberglass hood and pins.... /forums/images/graemlins/thinking.gif /forums/images/graemlins/waytogo.gif
  18. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    I'll do the same when you buy me one /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif
  19. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,224
    94
    Stevens Pass Highway, WA
    Just pickup some white lithium grease. Spray that on all the pivot points in your hinge and it will open and close like it is new. Even if you have new hinges they need to be lubed good.
  20. kennyw
    Jun 9, 2002
    13,224
    94
    My dad braced his '78 K30 with a couple pieces of angle iron. Just drilled thru the hood and bolted it on with 5/16" bolts /forums/images/graemlins/rotfl.gif But that hood wasnt much to start with either. Heck the whole body was patched together with patch panels pop-riveted into place and a new coat of rattle can paint. I'm just waiting for something to break that he can't fix so I can inherit the truck and restore it with a rust free body /forums/images/graemlins/whistling.gif
