Hood-Fender Gap Question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RiceDaddy, Sep 11, 2003.
  1. RiceDaddy
    RiceDaddy Registered Member
    Feb 3, 2002
    79
    Tejas
    I'm going to mount a CB antenna with a hood mount on the driver's side up near the cowel. The antenna mount sticks through the gap between the fender and the hood. The problem I have is that the gap on the passenger side is wider than the gap on the driver's side. The hood lines up pretty good up front by the grill(the gap between the fender and hood is pretty even on both sides). But, up by the windshield the gap is much more narrow on the driver's side. Almost like the hood isn't quite sitting straight. The hinges look like they are not bent. I also loosened the bolts holding the hood to the hinges and tried to position it side-to-side. The holes in the hinges, though, aren't really designed to allow you to move the hood side to side, only front to back.
    Does anyone have any ideas on how to even out the hood to fender gap up by the windshield? /forums/images/graemlins/thinking.gif
    Thanks /forums/images/graemlins/usaflag.gif 1980 K5
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Look in my webshots, I've got pics of my burb with the cb antenna mounted between the hood and fender /forums/images/graemlins/thumb.gif I have not noticed any rubbing or anything and its been there for the yr and a half i've owned it.
  3. RiceDaddy
    Feb 3, 2002
    79
    Tejas
    The problem is that there really isn't enough gap to get that hood mount to fit in there. Also not enough gap to run the coax through without pinching it.
  4. tRustyK5
    Jul 23, 2000
    36,169
    1,367
    E-town baby!
    You're probably missing one of the rubber wedges that center the hood. They attach to the inside upper lip of the fender and should keep the gaps even if they're all there. I am pretty sure there should be two of the wedges per side...
    The hinges have very little lateral support or strength.
    Rene
  5. RiceDaddy
    Feb 3, 2002
    79
    Tejas
    I guess I didn't realize that those rubber wedges help center the hood. Currently I don't have any. just the round adjustable stops on either side up by the grill.
    Maybe if I install them, it will center up the hood. What do you think?
  6. tRustyK5
    Jul 23, 2000
    36,169
    1,367
    E-town baby!
    That's what they're there for /forums/images/graemlins/thumb.gif
    Rene
  7. RiceDaddy
    Feb 3, 2002
    79
    Tejas
    Rene, Thanks very much for the help.......but
    I just installed four new rubber wedges in the factory locations (I was missing all four). It didn't really help any. Still a larger gap on the passenger side. Enough that I can't run the coax in between without pinching it.
    What should I try now?
  8. tRustyK5
    Jul 23, 2000
    36,169
    1,367
    E-town baby!
    I'd guess you'll have to try and adjust the hinge bolts where it attach's to the hood. I have the same problem with my hood. I replaced the fenders and just last night put the 4 rubber wedges on. It helped a little but my hood still doesn't line up nicely either. My hood has been on and off a few times...
    I would think if the hood was moved 'up' on the one side and down on the other it would have to line up better.
    Rene
  9. toy4fun
    toy4fun 1/2 ton status
    Sep 10, 2002
    220
    Helper, UT.
    You might check to see if your fender and door line up, you may have lost a spacer in the fender or have room for one more spacer to give you enough room for the cable/forums/images/graemlins/thinking.gif
  10. RiceDaddy
    Feb 3, 2002
    79
    Tejas
    I got it /forums/images/graemlins/grin.gif
    Thanks again for your help Rene. After work today I loosened the bolts that hold the hood to the hinges. Slid the driver's side back a little and brought the passenger side forward just a little too. It lined everything up perfectly. All is well now.
    Thanks for helping me get over my incompetence.
  11. tRustyK5
    Jul 23, 2000
    36,169
    1,367
    E-town baby!
    Glad to help...I'll be tweaking my hood a bit on the weekend./forums/images/graemlins/crazy.gif
    Rene
  12. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    I have a large gap on each side of my hood to the fenders, larger than stock, but most people only notice the hood...
