Hood popping tricks
Discussion in 'The Garage' started by 78 k5, May 25, 2005.
  1. 78 k5
    78 k5 1/2 ton status
    Jul 8, 2004
    261
    Auburn, AL or ATL, Ga
    Anybody know a way to get a later model (1990) hood popped when the pull cord in the cab doesnt work :confused:
  2. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Is the cord connected but the hood just doesnt pop up? Or is the cable broken and you cant open the hood at all? My latch always sticks a little so after I pull the handle I go and give a little rap on the top front portion of my hood. That always seems to get her loose. I have been doing it that way for the last 5 years and has worked everytime. But last year I took the latch apart and cleaned everything off really good, sprayed a litttle lithium grease in their and tossed it back on and now it works every time. I dont have any suggestions if your cable is broke, just hope nothing goes wrong in your engine for the rest of the time that you own your truck. :rolleyes: There was a post not too long ago about how to open your hood with a broke cable I think.
  3. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    agreed
    we need to know if you hear the cable pulling the lever.. or is the cable disconnected...
    mine was acting up... I had to pull the lever then grab and YANK the hood hard... opened it up and white lithiumed the hood lock latch and the springs on the sides...
    now opens with every pop :grin:
  4. 88sub4x4
    88sub4x4 1/2 ton status
    Sep 22, 2002
    792
    Long Island, NY
    My cable was stretched out, so I used a screwdriver to get it open, then I hooked up a coat hanger to pull in case the handle didn't work.
  5. K5er4Life
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Nice, I like it, good ole redneck style but hey whatever works right? :saweet:
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeah coat hanger or baling wire backup is a smart move for sure, its saved me a couple times in the past
    you may have to remove grille to get at the lever that will release the safety catch if the cable is broken or whatever
    good luck
  7. 78 k5
    Jul 8, 2004
    261
    the cord is just stretched. Beat on the hood huh :confused:
  8. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    hood beatings
    my hood on my 1990 blaze always sticks even after a grip of wd40 and all you do is smack the left or right corner of your hood and it should pop up
  9. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    Next time you get it open, spray the latch down with White Lythim Grease, not WD-40. WD-40 will actually make it stick. My '86 Jimmy hood had the notorious sticking hood until I lubed it properly. Now it opens like new.
  10. K5er4Life
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Most definitely, little lithium grease makes it like new.
  11. 78 k5
    Jul 8, 2004
    261
    got it and have a coat hanger "saftey" cord. thanks
  12. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    This just happened to me, and I what I did was, pull out the grill and you can reach up in there and pop the hood yourself. Once I figured this out it was really easy to do. There is a lever and if you pull it towards the drivers side fender, it should open it.
  13. RootBreaker
    Nov 29, 2001
    5,117
    173
    how did you get the grill out?
    I have screws under the hood part so couldnt get the grill off...
    years ago I just took shears and cut a hole in the hood and re-connected the cable... (had a spare hood....)
  14. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    same here, tho any type of lubricant on the latch always fixes it right up.the sweet spot on my truck is on the middle where the latch is, slightly towards the drivers side. when u pull the cable u gotta make sure it doesnt slide back and lock, so dont slam your door inbetween pulling the cable and hitting the hood.
    i kinda like it when my hood sticks, causs then you get to do hit it like the Fonz :D
  15. hunter
    hunter Registered Member
    Oct 28, 2004
    52
    Houston,Texas
    lmfao...thats what I do...open the door...pull the latch...then hit the hood right in the front/middle at the ridge....works every time....fonzie style :D
  16. theitalian404
    theitalian404 Registered Member
    May 7, 2005
    75
    Georgia.
    Pri-bars can be put to more uses then breaking into houses. :D
  17. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    Dont call the fire dept!...
    The local fire department wastes NO time looking for the hood latch,or trying to see if it works...they just CHOP it open with a big fire ax!! :yikes: :yikes: --no time to waste if its burning,right? :whistle:
    other ways to
    open it are.. :weld: :hack: :grind: :ignore:
  18. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,014
    844
    Pinckney, MI
    Do what I did leave a bottle of Power steering fluid sitting right under the latch, go in to watch football or some tv show, come back out when its dark. Shut the hood and go.... :doah: :doah: Then dislodge the bottle from the latch, and its as good as new. My hood opens everytime now :)
  19. suthrnchvyguy89
    suthrnchvyguy89 Registered Member
    Oct 10, 2004
    51
    charleston, sc
    mine doesnt work either, i just pull it the thing, go around front and push down one it about a foot away from the center chevy thing on each side a couple times and that always works, you just gotta know how to push it just enough not to shut it all the way again
  20. MuddQueenK5
    MuddQueenK5 Registered Member
    Oct 15, 2005
    84
    Glenside, PA
    Hrm I am having a similar problem now. I pull the hood latch and I hear the pop but then I go to pull on the hood nothing. I am scared I am going to break a bracket or something underneath so I only tug a bit. I can get my fingers on the corners and when I work my way to the center it just gets tight. Any ideas?
