Hood pops up in rear
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Suffergauge, Dec 18, 2002.
  1. Suffergauge
    Suffergauge 1/2 ton status
    Aug 1, 2002
    153
    Olympia, Wa.
    How do you fix this problem? I have seen it on almost every old chevy. It drives me nuts! I can push it back down but as soon as I drive it pops right back up. Springs shot? Hood not adjusted right? My search didn't really help. I am sure there is a fix for this and it is bugging the hell out of others too.
  2. balzackks84
    balzackks84 1/2 ton status GMOTM Winner
    Aug 22, 2002
    1,344
    portland, oregon
    Did you make sure all the spring bolts were tight? The ones on the hood and the fender.
  3. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    Just to save you some money - I purchased two new springs and installed them last week. The hood opens faster and is harder to close, but it didn't solve the back sticking up problem (made it worse on one side). It may be a combination of adjustment and new springs, but I haven't tried adjusting it again yet.
    When you find out what it is, let me know.
    _____________
  4. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I had this problem on my older truck and its just the hinge mechanism wearing out. We used to make the holes longer on the hinge part that bolts to the fender so we could drop it all the way down so it was level. Still opened bad cause it was still worn out though.
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I've got the same problem on the drivers side of my old 76 K5. I just try not to look at it. /forums/images/graemlins/grin.gif /forums/images/graemlins/ignore.gif /forums/images/graemlins/ignore.gif
  6. FL84K5
    FL84K5 1/2 ton status
    Aug 19, 2001
    936
    Sarasota, FL
    You dont need those Being reliable is a major goal for mine. I like to hit the back wood trails that don't see much use. So The mods I'd recomened would be: 3/4 Ton axles (cheaper then 1 Ton, but 1 Ton is better) and either a 4" or 6" suspension lift, and 33" to 36" tires. Now I don't know how you feel about trimming fenders, so I'll leave that one alone. That'll get ya out in the woods.
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    OK here it is.
    The problem is in the brakets like someone mentionned.
    The springs don't fix anything.
    2 ways to fix it, either get a new set or used in good condition, and that is easy to check if you hold it without the springs on it and wggle it and try and open and close it, if you feel any slop when it's on the hood the slop is ten times more because of the length of the hood (leverage).
    The second is to fix yours. Depending on the cost, I couldn't find any replacement so I had no choice, I drilled the rivets out, noe I saw the oblong holes. I drilled them out in a bigger size until I got a round hole.
    I machined some rivets for that size, and installed them in and pounded the edges for a tight fit.
    Grease them and install them.
    It made a world of difference and it cost me $10 in material, since I had the lathe. /forums/images/graemlins/thumb.gif
    But I think you can find a good set if you look hard enough or buy new.
    I have a couple of sets now that I took of some clean trucks.
    If anyone is CA and wants them, feel free to message me.
    I don't want to suggest this to anyone far because I think the shipping would cost too much but if someone is desperate I am OK with shipping them to ya.
  8. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I had a '72 truck (I found out the hard way).
    I left the springs on the hood hinges, and took the hood off. Put the hood back on and voila' the rear would pop up.
    I have a '73 Blazer same deal, I took the hood off without taking the springs off first, blam-O the rear pops up.
    So I think - the hinges buckle under the weight of the springs and they do not close again. And/or the hinges have worn through. The trick, is finding a good set of hinges, or replacing the oblong ones as Iceman has.
    LMC sells these for $29.99 EACH! ouch.
    Good luck.
  9. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    EASY FIX:
    Loosen the hinges on both sides. Have a friend push the hood open as far as it will open which will rotate the hinges in their loosened position, then tighten it down while hey hold it like this. When you close the hood the back will be resored back to its original flush position. The problem is... its really hard to do this alone!!!
  10. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Did the adjusting thing.
    If the hinges are good, it will work, if the hinges are sloppy it gets better but you still have some play. Plus there isn't much room for adjusting.
  11. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Fender trimming is especially hard on the hinges. I've busted two already.
  12. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    EASY FIX:
    I second this. I remember reading a post about someones hood flying open on the road and the bending back fixed this issue...
  13. Suffergauge
    Aug 1, 2002
    153
    Olympia, Wa.
    FL84K5... Huh? Already lifted and modded...
    Everyone else thanks for all the info. It is one of the many things on my noid list. It just happens that I see it every time I drive so I am constantly reminded of how much it bugs me /forums/images/graemlins/grin.gif .
    Borrego, what about using a 2x4 or something to hold it open while adjusting? I live in the woods, not to many neighbors. I am gonna try the 2x4 trick just for grins.
  14. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    That will work, that's what I had to do since I never have any helping hand.
  15. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Yeah, that or a rope over a tree works well too! Only here the "association" would hang me by it!
  16. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    My take on this... I leave it that way. It's helps out if you have to open the hood when the body is twisted up on a trail /forums/images/graemlins/wink.gif
