hood problems
Discussion in 'The Garage' started by DieselDan, Sep 1, 2003.
  1. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    I was dickin around with the TV cable (POS 700R /forums/images/graemlins/mad.gif). 'Went around the block to check the shifts and I didn't have the hood fully closed. Well of course it flys open at about 25-30 mph. I try to look nonchalant closing the hood in the middle of the street /forums/images/graemlins/blush.gif I hear the hood take a bite out of the cowl as slam it shut; so much for the fresh paint /forums/images/graemlins/angryfire.gif
    Back at the house, I try to adjust the hood away from the cowl. But now it sits low on the passenger corner. I played with it for an hour, it still sits a little low.
    Any advise? Besides make sure the hood is fully closed before driving /forums/images/graemlins/smirk.gif
  2. ryoken
    Jun 13, 2003
    29,621
    1,371
    Jersey Shore
    your up down adjustments for the back of the hood are where the hinge bolts to the firewall and fender, not the hood.
    if the hinge has gotten tweaked, one old bodymans trick is a 2x4 or block of wood strategically placed (for yours prolly laying from cowl to fender in the corner behind the hinge) then slowly close the hood till appropriately tweaked.
    hope that helps... /forums/images/graemlins/smile.gif
  3. DieselDan
    Jan 27, 2001
    1,056
    Vermont
    Anything helps. Do I have to pull the fender to get to the hinge bolts? It's been awhile since I had the whole front end apart. 'Guess I'll try beating on my Jimmy with a 2x4 some more /forums/images/graemlins/smirk.gif
  4. ryoken
    Jun 13, 2003
    29,621
    1,371
    Jersey Shore
    if i remember correctly, there are 2 going into the firewall, one low, one high. then theres one going into the fender perpindicular to those 2. so, no fender removal. try loosening all of those and raising the hinge.
    sounds like you may need a trip to the boneyard for a new hinge tho /forums/images/graemlins/frown.gif
    good luck man /forums/images/graemlins/smile.gif
  5. DieselDan
    Jan 27, 2001
    1,056
    Vermont
    DAMN, on top of it all... I turned <font color="blue"> blue </font> /forums/images/graemlins/eek.gif
