Hood wont open, need some serious help............
Discussion in 'The Garage' started by Silver84k5, Feb 6, 2003.
  1. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Is there a way to get my hood open without being able to pop it? and without cutting or bending it all up. This is freakin ridicoulous. /forums/images/graemlins/angryfire.gif
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Is the cable busted? Or, did it just not release all the way when you pulled on the hood release?
  3. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    well heres the story, the other day it did the same thing, it would release but when you put your hand in there and pulled the latch it wouldnt open, i look closely, and one of the bolts had come loose on the latch that holds it to the crossmember, we fixed that and adjusted the hood at the same time....... now when i pull the cable, it makes the sound of popping the hood, and it comes up a little bit, but it doesnt come up enough to grab the lever under the hood and release it so it opens.... grrrrrrrr this doesnt sound like it makes sense, kinda hard to explain.
  4. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    see if you can grab the handle through the grill. I have done this on my ford and acouple of chevys.
  5. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Mine does the same thing. Take the palm of your hand ,and hit the edge of the middle of the hood.
  6. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    I tried that, but that handle didnt do anything.....
  7. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    That used to work, but trust me i have beat the hell outa that thing tonight trying to get it open, thats not it.. Looks like fiberglass hood here we come.......
  8. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    Thx for responses. looks like High steer is gonna have to wait, till i get a new hood /forums/images/graemlins/angryfire.gif
  9. luckdawg
    luckdawg Newbie
    Oct 16, 2002
    albuquerque new mexico
    Hey I had the same problem & I had to take off the fender to get the latch. Since this is a common problem with Chevy's, take the latch assembly out & get hood pins. Drill two holes and you'll never have that problem again! Anyway that's my two cents. Hope I was of help Good Luck!
  10. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    If you can rach up there, try and pull the cable...if not, take out the drivers side wheelwell and pull the cable from there, or try to get to the latch
  11. Silver84k5
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    dont you need the hood up to get the fenders off? or the inner fender for that matter?........... If i dont get the fiber hood, i will definatley get hood pins..........
  12. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Nope, 3 bolts bottom front, 2 bolts in the rear and about 6 to 9 bolts along the lip of the wheel well and the inner fender will drop /forums/images/graemlins/thumb.gif
  13. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Standing in front of the truck, smack it with an open hand pretty hard to the left of the crease about 4-6" back from the front... does that make sense? It should pop up if it's pulling what mine did. It's actually a nice anti theft device. Nobody could figure it out ever..... /forums/images/graemlins/grin.gif
  14. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    My hood needs wack just right to open.Hit it wrong and it relatches itself.Been that way for years. /forums/images/graemlins/grin.gif /forums/images/graemlins/thumb.gif
  15. ChevyHuny
    ChevyHuny 1/2 ton status
    Aug 17, 2001
    2,279
    Washington State
    My 85 k5 used to need to be whacked like that but the whack always worked. My 96 sometimes gets stuck but if you whack it the same way as the K5......it closes. /forums/images/graemlins/ooo.gif /forums/images/graemlins/mad.giflol
    Josh not to make this situation any more frustrating but I got a good chuckle out of the image of you getting all ticked and whacking the heck out of your hood. [​IMG]
    I hope you have it all worked out now though. /forums/images/graemlins/grin.gif
  16. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    I had that same problem with mine. Turns out the pin in the hood that the latch catches onto had come out of its mount. My hood's an aftermarket that the PO put on when he changed to 91 front clip. I was able to get a screwdriver in there and work the latch and I popped the hood open. The pin fell out. Its about 3" long and 3/8" in diameter and at the last 1/8" or so the diameter reduces to 1/4", I think its supposed to be spot welded in , but it IS made in taiwan. I ended up drilling and tapping a hole in the end where it reduces to 1/4" then I reinstalled it and put a 10-32 stainless screw in to keep it in place. Since the hood sees a lot of vibration I used loctite and a lock washer. So far so good, it's been about a month. But as far as initially getting the hood open, that was a major PIA. Good Luck.
  17. RLBstein
    RLBstein 1/2 ton status
    Jul 2, 2000
    179
    Pensacola, FL
    I just have to say that the whack the hood idea is histerical. I used to have to do that to mine before the rebuild. Maybe Chevy should just put that into the owners manual.
    TO OPEN HOOD:
    1. Pull hood release lever.
    2. Take palm of hand and "smack" hood on left side of crease.
    3. Move lever over and raise hood.
    4. If hood does not pop up after step 2, repeat step 2.
    DISCLAIMER: Damage done by incorrect use of step 2 will void warranty.
    /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
