HOOK A NEWBIE UP
Discussion in 'The Garage' started by luv2xclr8, Jan 21, 2004.
  1. luv2xclr8
    luv2xclr8 Registered Member
    Jan 20, 2004
    6
    BEECH BLUFF, TN.
    SERIUOSLY GUYS, NEED SOME HELP WITH MY 72 K5 BLAZER. I KNOW
    YOU 4WD GURU'S SHUTTER AT 2WD BLISS, BUT I REALLY NEED SOME
    DATA ON THE DIFFERENCE BETWEEN A 2WD AND A 4WD FRAME WIDTH.
    CAN A 4WD BE CONVERTED OVER USING A 2WD SUBFRAME CROSSOVER
    AND SUSPENSION? ALL THE PARTS LEFTOVER WILL BE CHEAP TO BUY.
    ALSO, ARE 5 LUG PICKUP AXLES AND 6 LUG BLAZER AXLES SPLINED
    THE SAME OR ARE THEY DIFFERENT? BOTH AXLES ARE A 12 BOLT.
  2. txfireman110
    txfireman110 1/2 ton status
    Nov 1, 2003
    294
    San Angelo, TX
    So, just for the sake of clarification, you want to go FROM 4WD to 2WD /forums/images/graemlins/confused.gif
  3. 4xrick
    4xrick 1/2 ton status
    Sep 14, 2003
    1,102
    kirkland Wa
    why on gods green earth would you want to go from 4 wheel to 2 wheel /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Wouldn't it be nice to have a topless 4wd blazer. It would be cheaper to buy a pickup and then cut the top off if you want open air 2wd.
    Just an opinion. /forums/images/graemlins/thumb.gif
  5. luv2xclr8
    Jan 20, 2004
    6
    BEECH BLUFF, TN.
    CAN'T GET 4WD HELP OR PARTS HERE WITHOUT GETTIN RIPPED.
  6. 4xrick
    Sep 14, 2003
    1,102
    kirkland Wa
    well they did make 2wd topless blazers just go find one probably alot less work
  7. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    just get a 2wd straight axle from a 50's truck /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif/forums/images/graemlins/thumb.gif
  8. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    QUIT TYPING SO LOUD. /forums/images/graemlins/rotfl.gif
  9. big k5
    big k5 Registered Member
    Nov 19, 2003
    88
    Sautee Nacoochee,Georgia
    you said you can't get 4wd parts where you live with out getting ripped.Have you ever tried mail order or the internet.Nowdays you can have whatever you want sitting at your front door with a simple bank debit card.the longest I've ever waited for anything is a week.
    4wd to 2wd........to each his own,but I don't understand WHY !
  10. GregB
    GregB Registered Member
    Apr 24, 2000
    6
    Newbies RULE!!!!
    ....so do pavement pounders
  11. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    Both axles are 30 spline. As long as you aren't using a early narrow width 12 bolt, the axleshafts should interchange.
    In another thread, I recommended that you ask your 4wd to 2wd conversion question over at www.67-72chevytrucks.com. There aren't alot of guys on this site with 2wd 67-72 trucks, so getting an answer here might be tough. Most of the trucks at 67-72 are 2wd, so getting someone to measure or take a pic of a 2wd frame should be fairly easy. /forums/images/graemlins/thumb.gif
  12. Grim-Reaper
    7,385
    Atlanta
    Just curious why you thing 4x4 parts are more? I know a lot of folks who travel the TN to buy parts.
    Well at least your going to make a more plentiful 4x4 into a not so plentiful 2wd. I been looking for one for years.
    For the record your not going to easily make a true 2wd K5 unless you find a real 2wd frame and swap them. The 4x4's have leaf spring rear and front suspension. a real 2wd 69-72 has 4 wheel coil. There is a guy who just posted some pictures of just such a converted K5. He had a few tips in the post.
    I go both way's. Once I find the right vehicle I'm going to build a K5 into a slot car of a ride and go run the twisties. I'm looking at building a 2wd Burb but more of a Prerunner style although there is a very cool looking dropped Burb in the 73-91 burb section on the other site.
    The 67-72 board listed above is proably going to be a little better source for the info you seek. That site tends to be more street and street rod biased. There as some folks there with some beautiful trucks.
  13. rjfguitar
    Aug 28, 2002
    9,095
    144
    california
    Newbies RULE!!!!
    ....so do pavment pounders
    WTF?...ok...sure... /forums/images/graemlins/rotfl.gif
