Hook coming off tbi?
Discussion in 'The Garage' started by inscape, Jun 30, 2004.
  1. inscape
    inscape Registered Member
    Oct 30, 2003
    82
    Washington
    There's 3 linkages to the throttle, 2 are cables and one is a plastic sleeve with a metal rod in it and a hook on the end. I don't see where it's suppose to connect to, TV cable? The tranny shifts fine so I don't know. I tried looking for a Chiltons manual, but only see them for an 87 and not 89, is there one?
  2. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    i believe that goes to the cruise control. there should be a diaphram a couple inches behind the throttle that it hooks to.
  3. duece21
    duece21 1/2 ton status
    Jan 18, 2004
    501
    Aurora, CO
    I agree! there should be a diaphram about 4 or 5 inches back from it where the hook should just drop right into a little metal ring attached to the diaphram. The other side(tbi side) is adjustable and just pops on w/ a little clip to hold it on.
  4. inscape
    Oct 30, 2003
    82
    Washington
    Thanks, I had to use pliers to vripm the hole around the hook so it would stay on. Another question, do ti spacers work? A couple different ones advertised 15+ hp, 22+ hp, better gas mileage etc. Is that true? I just have the stock intake setup, just replaced the filter today though.
  5. duece21
    Jan 18, 2004
    501
    Aurora, CO
    Your not going to notice super horsepower gains that you would by adding a better cam or heads, but I noticed a smoother and stronger acceleration and some better fuel economy. At least that is what I experienced w/ mine.
    Turbocity and CFM sell the best spacers. I bought the CFM kit w/ adjustable fuel regulator, injector kit, injector spacer, air-flow enhancer and 1" spacer. Warning, be carefull w/ the 1" spacer. It raised my TBI lines and caused one to rub against my body. Needless to say it caused a fuel leak and I had a small fire happen from it. /forums/images/graemlins/yikes.gif but easily fixed.
    Turbocity
    CFM Technologies
