Hooker comps #2453 & SM465
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by JIMs70K25, Jan 16, 2002.
  1. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    This has probably been asked, but I just searched through 3 months of header post and did not find it. Will the subject combo work, in regards to the clutch linkage? Anybody running them now? I looked at hookers site and read all the footnotes and it appears the linkage is not a problem. Thanks,
    <a target="_blank" href=http://community.webshots.com/user/70gmc>My 70 GMC</a>
  2. JIMs70K25
    Dec 31, 2001
    524
    Chesapeake, VA
  3. Quetzal_SJ
    Quetzal_SJ 1/2 ton status
    Feb 20, 2001
    123
    San Jose,Ca USA (BAY AREA)
    <a target="_blank" href=http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=firstgen&amp;Number=136518&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1>http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=firstgen&amp;Number=136518&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1</a>
    Here is a link to the same Q. I will have the same prob when my time comes.
    Lico
    <P ID="edit"><FONT class="small">Edited by Quetzal_SJ on 01/19/02 06:37 PM.</FONT></P>
  4. huggerk5
    huggerk5 Registered Member
    Aug 16, 2001
    25
    Amarillo, Texas
    Have you bought your ram horns? If so how much are they? I am running a pair I scrounged fron junk yard, but one of the ears to the collector was broken. I tried to fix , but did not last long. TIA.
  5. JIMs70K25
    Dec 31, 2001
    524
    Chesapeake, VA
    Have not bought them yet, probably late Feburary. My 70 GMC or <a target="_blank" href=http://communities.msn.com/jims70gmc>My 70 GMC</a>
  6. huggerk5
    Aug 16, 2001
    25
    Amarillo, Texas
    I am running them now. I bet they flow as good as some headers. Plus a little back pressure increases tork. So I've been told. Thanks for the information.
  7. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Whomever told HuggerK5 that backpressure is beneficial to torque is sadly misinformed about tuning an exhaust system. There are alot of variables in exhaust system tuning for high performance, and in order to make best power backpressure has to be minimal, along with the cross-sectional area of the pipes and their associated lengths set properly for the cam timing, engine displacement, crankshaft stroke, R/S ratio, RPM of interest, etc.
    Anyhow, a friend has a set of Hooker Comps on his manual tranny Blazer (used to be an SM465 Blazer, now has an NV4500), and they fit OK, but hung a bit low so he bent them a little higher. I'll try to find out what model number he got.
  8. huggerk5
    Aug 16, 2001
    25
    Amarillo, Texas
    Steve, very interested in your statement. My motor dynoed at 466 lb ft torque with hooker comps. They had 3" collectors and I made them fit it was a bad dream. But that was the numbers on the water brake. How much do you think I have % wise? Best guess. I am not trying to be smart I just don't know.Also it the hassel of headers worth the trade off. I know run the 2.5" ram horns. If it is a large difference I may go back. Your thoughts please.
  9. Steve_Chin
    Mar 6, 2001
    1,126
    I'm not sure what the flow through the ram's horns is like, but from the looks of them they don't offer any pulse separation. Given that, I'd bet that with an engine that makes more than 450 lbs*ft. of torque the manifolds would lose between 5% and 15% of power through the range with a set of manifolds versus a set of reasonable headers. With a good set of headers compared to the manifolds, the losses would be greater.
