hooking up a factory tach
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89 Blazzer, Jul 28, 2001.
  1. 89 Blazzer
    89 Blazzer Registered Member
    Aug 9, 2000
    29
    I am hooking up a factory tach. The tach is labeled as to where the wires go (ground, 12v, coil). Where do I hook up the wire that goes to the coil? I have an 89 TBI. The coil is external to the cap. there are 2 connectors that snap on to the coil. I think there are 4 wires total. Anyone know which one I need to tap into?
  2. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    If I remember right, one of the four wires coming from the coil doesn't go anywhere, it ends a few inches from the coil. That is the tach lead. Although there are 4 wires coming out, they are really two pairs of the same. (ie they could have used only 2 wires, they join together inside the coil.)
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
