hooking up a kick down cable
Discussion in 'The Garage' started by adamforsythe, Jul 9, 2005.
  1. adamforsythe
    adamforsythe 1/2 ton status
    Oct 16, 2004
    1,394
    Maine
    Hello,
    How the heck do you guys hook up your kick down cables? I can't get the cable to go onto the wire sticking out of the tranny.
    Adam
  2. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    Ya gotta drop the pan Adam, unless you're really good.....
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Drop the pan? Why? I've never had to drop the pan, I always hook the end of the kick-down cable to the wire first then feed the cable up the firewall to the carb second. Works out great that way.
  4. adamforsythe
    Oct 16, 2004
    1,394
    Maine
    How would you do that? There's all a funky bend at the top of the wire that I can't get the hole to loop around.
    Adam
  5. adamforsythe
    Oct 16, 2004
    1,394
    Maine
  6. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    No, you don't have to drop the pan.
    If you have already hooked the cable up at the top of the engine, disconnect it.
    Then go down to the tranny and pull the cable out of the sleeve. It should pull out a couple inches. That should be all you need to hook it to the arm sticking up out of the hole that the kick donw cable goes into. Yo may need to use a pair of needle nose pliers to pull the little arm up a bit so you can hook the cable to it.
    Once you have the cable hooked to the arm, bolt the cable to the tranny (the little 3/8" bolt) Then fish it up to where it bracket is on top of the engine. Hook it up.
