Hooking up a york
Discussion in 'The Garage' started by 84CUCV, Sep 28, 2005.
  1. 84CUCV
    84CUCV 3/4 ton status Premium Member
    Jul 1, 2002
    7,115
    NJ for now
    just got two. One is good one needs a redone.
    one has #s
    M 173745
    below that
    AMC- 5461585
    second one has #s
    m 605402
    below that
    AMC-5461585
    Anyone know how to find out more about these?? Hope i didnt spend 40 for nothing as always thanks guys
  2. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    If you can find the equipment tag and post me all the numbers in order on it I can look in my book to see what model it is,,
    Should have a Line of numbers that start with No. then numbers , then under that is should say Pt, then more numbers and letters..
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    There is some pretty good information on www.onboardair.com and they have a forum that is very useful. Also, run a search both here and on PBB as these are the topic of many discussions on both.
  4. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    cool thanks guys, the #s on top are the No # and the ones on the bottom are the pt #s
    mike
  5. NoSmog73
    Sep 28, 2001
    2,348
    lodi,ca
    I have a York service manual for the 206-209-210 but those numbers do not match what is in my book...Could be a differant model ????
    Should be something like
    A 01234567
    ER 210L - 00000
    00-00
  6. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    I found a tag above the cluch and that was it. No other #s on it. looks like i wasted 40 bucks thanks mike
  7. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    No you did not. AMC retagged all the yorks i have ever seen installed in them. Remove the clutch and pully and look at the end of the crank shaft. Than you will be able to ID it according to the shape.
    Or you could just ship them too me and i will "throw" them away for you :D
  8. cbbr
    Jul 17, 2004
    14,681
    This manual should help a great deal. It shows how to take them apart, and how to identify the displacement (pg. 17). Hope that it helps.
  9. 84CUCV
    Jul 1, 2002
    7,115
    NJ for now
    thanks cbbr anything is better then what i have now. Bumped into the guy i got them off, both are from heeps. thx again
  10. badfish4tail
    badfish4tail 1/2 ton status
    Mar 1, 2005
    1,684
    Long Beach
    Hey guys
    Since your on the topic of Yorks
    I bought a compressor that was advertised as a york with no photos
    When I rcvd it, it looked just like a York but had a tag that read:
    No. Y535429
    PT C8AA-2875A2
    068
    FoMoCo.
    My question is that is this the same as a york or does FoMoCo rebuild yorks?
    Wanna make sure every thing I buy to install will fit this :o
  11. readymix
    May 30, 2004
    6,706
    26
    As far as i know the FoMoCo's are just rebadged yorks
  12. badfish4tail
    Mar 1, 2005
    1,684
    Long Beach
    Thats what i thought....Thanx
