hooking up kick down cable on th350?
Discussion in 'The Garage' started by LKJR, Sep 8, 2005.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    what all is involved in hooking up the dtent cable on at th350 on the tranny end? tpi swap going on and I need to get this done. Do I have to remove the pan or is there a way to do it without that? since the pan dosen't leak...
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Th350's are easiest IIRC , you remove the little bolt that holds it on , and the little wire thingy threads into the eyelet on the cable end .
    Haven't done it in forever , just now got my first TH350 since my 76 Laguna .
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I've just put a TBI motor in my '78 with a th350. It's easy to hook up as Pauly said. But I had to put a domed allen bolt and nut in the slider at the throttle body end to get enough adjustment on the kick down, but that could be the way I made my throttle/kickdown bracket! :doah:
  4. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    " Do I have to remove the pan "
    I'm sorry to say you do have to remove the pan. :(
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    ??? :confused: The cable can be hooked up from outside.
  6. fatbob
    Jul 3, 2003
    420
    Phoenix, Az
    I couldn't get it unhooked so I had to drop the pan. :dunno:
    Maybe it depends on how much room you got to work with or is there a trick I missed. :thinking:
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Maybe you need some more attitude!! :D I didn't say it was easy. It says in the manual somewhere that harsh language and a Mossberg help. :D :D
