Hopefully my last 205 question
Discussion in 'The Garage' started by mr_clean, Feb 11, 2005.
  1. mr_clean
    mr_clean 1/2 ton status
    Sep 21, 2003
    348
    Sacramento, CA
    I'm just about done rebuilding my 205 and had a quick question. (Ok, maybe 2)
    1. When I assembled the rear output shaft and set the cast iron output shaft housing over the shaft, the oil deflector part of the housing touches the gear on the shaft. Is this supposed to be like this? When I put it back in the case I don't feel/hear it rubbing, but on the bench it clearly touches.
    2. Again on the rear output shaft. In regards to the needle bearings inside the shaft (not the ones between the gear and shaft), there is a washer and a wire clip. What is the order of installation for those parts? I'm hoping it's bearings, washer , then wire clip to hold it all together, but the bearings fell out when I disassembled it so I couldn't see for reference.
    Thanks for all the help,
    Scott
  2. therobzilla
    therobzilla 1/2 ton status
    May 15, 2001
    1,307
    Gilbert, AZ
    For question number 1 I need more info, unclear what you are talking about.
    For question number 2, it's bearings, washer, bearing and wire clip. Use a bunch of bearing grease to hold it all together while you are putting it back together.
    Rob
  3. mr_clean
    Sep 21, 2003
    348
    Sacramento, CA
    Thanks for the help, and sorry about not being clear.
    on the output shaft housing where the breather is located. Inside the housing is a ledge that looks like its only purpose is to deflect oil from reaching the breather. That part of the housing hits the gear when I lower the housing over the shaft assembly.
    I'll try to link a picture...
    On the second part, I think we might be talking about different roller bearings.
    I'm talking about the bearings on the inside of the shaft where there is only 1 row of roller bearings.
    Again I'll try to link a picture
    Thanks,
    Scott
  4. mr_clean
    Sep 21, 2003
    348
    Sacramento, CA
    ok, here's a link to the article I am using...
    http://okcnetworks.com/bronco/205/np1.htm
    the picture for question 1 is at step 73. That is the tab I am talking about that is rubbing on the main gear.
    the picture for question 2 is at step 82 picture 2, but it looks like that just answered my question. (man I looked all over that article last night... DOH!!!)
    Thanks again for the help!!!
    Scott
