hopefully this was enough
Discussion in 'The Garage' started by down4thakrown, Jul 9, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    maybe its about 1/2 way down my drive shaft, my custom xmember goes across the frame for the rear body mounts of the cab. there were about 3 inchs inbetween the driveline and x member. so i notched it out some anybody think this could still cause a problem :confused:
  2. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    this is a better one
  3. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Jeez learn how to resize pics :doah: :D
  4. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    ive been trying
    do you adjust the size in the pic or on the camera??
    think my drive line will clear the xmember when suspension is compressed
  5. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I would notch that cross beam for better clearance - I think it will hit the way it is currently configured. Better yet, notch it and make a drive shaft hoop while you're at it.
  6. dremu
    Feb 27, 2000
    15,957
    450
    East of San Francisco
    Search for the resizing info; you can prolly do it in PaintBrush depending on your version of Windows. Your camera prolly also came with software to do it.
    I have attached smaller ones for our viewing pleasure.
    I think the kicker is how far forward the drive shaft goes; I have less clearance than that on my front shaft to my doubler crossmember, for instance, but that's right by the end of the shaft.
    I can't tell from your pix, but if the crossmember is close to the end of the shaft, I don't see the thing hitting even under compression.
    OTOH, if it's in the middle and you're gonna have crazy flex up on both sides at once, maybe.
    EDIT: Mouse has a point (Mouse, do you make movies of the girl in the red dress, a la The Matrix? :D) ... I wouldn't notch it 'cuz it would weaken it, but notching + driveshaft hoop would be as strong or better, and keep the thing from flying off on the oops.
    -- A
  7. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    I resize all mine in paint.
    Copy the picture into paint.
    Go up to image.
    scroll down to stretch/skew.
    And in the stretch box change the 2 that say 100% to something lower.
    Click ok
    close box
    save pic
  8. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    i'll try notching it out and reinforcing the top of it with some angle iron or somthing. and make a loop too
  9. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    got the picture thing fixed :saweet:
    i hope notching that beam will be enough :confused:
  10. down4thakrown
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    new pix at the top
    man that stuff got thick at the top :eek1:
