Hopefully this works
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by the fall guy, May 29, 2005.
  1. the fall guy
    the fall guy Registered Member
    Jul 1, 2004
    35
    My buddy is going to replace the accel dist. with a rebuilt stock one. Ever since i replaced the distributer with a accel it has knowcked and run like crap. Everything was hooked up good but hopefully this will work everything out. Anyone have the same problem?????
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    accel parts SUCK i tryed 2 new dist and coils and no go. but every time i put old worn out gm back in fired up a.o.k. take the accel and trash it. just my opinon and past trubbles.:D
  3. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I am running an Accel distributor and have had zero (0) problems. I have put in heavy springs to slow the mechanical advance and set total timing to 28 degrees. I don't have any knock on an engine that I rebuilt in March.
  4. the fall guy
    Jul 1, 2004
    35
    I also put heavy springs in the dist. but still knocks and runs bad. idunno. but eveything started when that dist. was put in. Also i turned the vaccum advance screw in the nipple to about 2 turns (they recommend 4) and still sucks.
  5. PaloAlto_K5
    PaloAlto_K5 Registered Member
    Jan 16, 2005
    23
    Palo Alto, CA
    My Accel run no prob, truck purrs like a....ok, well rumbles perfectly. Smoother than all the others that I run with out here...
