Hoping someone might be able to help find a part...
Discussion in 'The Garage' started by K5thatShmobs, Feb 27, 2003.
  1. K5thatShmobs
    K5thatShmobs 1/2 ton status
    Sep 27, 2001
    353
    San Luis Obispo, CA
    Im looking for the seal that goes inbetween the front driveshaft yoke and the output shaft itself. Im not refering to the seal that you press into the casing, its the circular black rubber piece that seals up the end of the splines on the shaft.
    A GM part # perhaps? I dont think a kragen, autozone, napa type place would have it.
  2. K5 NUTT
    K5 NUTT 1/2 ton status
    1,611
    Grand Junction Colorado
    If i get the jist of what you are looking for...checker sells them for about $8....PN# BK1...made by SKF....comes with the double lip seal...i believe the dust shield for the axle stub...plastic spacer and the bearing for the inside of the spindle..
    DW
  3. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    i know what your talking about...not sure what its called though....my good friend who rebuilds t-cases usually throws them out and uses gasket sealer on the splines before he puts the yoke on....
  4. K5thatShmobs
    Sep 27, 2001
    353
    San Luis Obispo, CA
    So maybe I could just put a good bead of RTV on the end of the splines and slip the yoke over it then?
  5. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    That's waht I do, put a heavy bead of silicone around the base of the threads on the output shaft. I let it set just a little bit and then tighten the nut to spec. The nut pushes the silicone into btwn the splines.
