Hopping up a 350 TBI
Discussion in 'The Garage' started by MudFlap, Nov 10, 2003.
  1. MudFlap
    MudFlap 1/2 ton status
    Dec 2, 2002
    250
    Winston-Salem, NC
    I have searched for hours, but I could really find what I wanted.
    I have a 89 Blazer with the stock motor. Right now I have just exhaust manifolds and open pipes, but I will be putting in headers and building the rest of the exhaust system. I also have a K&N filter.
    I will be building a motor in a few years for the truck, probably a 383 or just building a better 350, but for now, what should I do to hop up my truck, it would also be good if anything that I do to the engine now I could also keep for the engine when I build it.
    I was thinking cam and intake, what cam and intake should I buy? Also will I need to do stuff to the TBI, if so what do I need to do?
    It would also be good if I didn't do anything that would make me have to get a custom burnt chip, because I know that I will be getting one when I build the motor down the road.
    Trey
  2. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    Edelbrock makes a cam and intake kit for the TBI set up, i ran that and I Hypertech chip that you can pick up at any outfitting store. If you want to add even more you can do the TBI to MPFI conversion that replaces the manifold and TBI; then only stock piece left is the throttle body, stripped of its injectors. It will give you some decent HP gains. AND if you do the conversion you get a chip that plugs into your ECM.
  3. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    As far as intakes, theres a cheap factory secret there. Try to track down an old mariene intake, they are factory highrises that usually dont cost much more than $50-$75, that should give you a bit more cash for that 383, while getting a bit more oomph out of the 350
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I think intake and cam are a good way to go after headers and exhaust. Don't go to big on the cam. Call a bunch of cam manufactures and ask them what cam you should run. You can also swap on a 454 throttle body that has bigger bores and will flow more air.
    http://members.shaw.ca/betterthanyou/28to43/28to43.htm
  5. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Just add boost or juice. /forums/images/graemlins/deal.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/rotfl.gif
  6. dyeager535
    26,979
    If you plan on running a larger motor, or one that you might turn a bit higher, an intake now is kind of pointless. (as is a cam, etc)
    If you are going to build a motor from scratch, get some heads to match a better intake. AFR's, Pro-toplines, Vortecs, ANYTHING with a better design than the stock heads. There is a LOT of power to be had in the heads.
    Since the heads and intake will make such a large difference, burning a new chip (or 5 to get it right) is going to be a necessity, but doing things the right way the first time is cheaper in the long run. Unless you can find some cheap used parts now.
    Better to save up the money now for better parts later, instead of spending money on parts you won't use on the next motor. Headers are a good start.
    My opinion,
  7. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    Go to www.tbichips.com This guy helped me out a bunch on my daily driver. Click on TBI mods and there is a ton of info there.
  8. Hardcore
    Hardcore 1/2 ton status
    Apr 25, 2003
    458
    New Orleans, LA
    Crane Cam #114122 /forums/images/graemlins/thumb.gif
    Edlebrock TBI intake and 454 or TurboCity TB
    If you want more get a set of World S/R torquers
    PM Thunder, he is the /forums/images/graemlins/pimp1.gif daddy when it comes to TBI upgrades. He's helped me out a lot.
    Corey /forums/images/graemlins/k5.gif
  9. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    For now if I was to put on a set of heads, cam, intake, new throttle body, and get a chip burned, I could use all of that stuff again, when I build my motor except for the chip, right? Even if I go to a 383 can I still use everything?
    Will I need to get a custom chip burned?
    Is this a good idea, to do that now, or is there any reason why I should wait to do some of the things mentioned above?
    If I was to get a set of Vortec heads (or any other head that yall recommend), a good cam and intake, a 454 throttle body and a chip burned, how much horsepower could I expect?
    Thanks,
    Trey
  10. dyeager535
    26,979
    Yes all that stuff could be used on a new motor, even a 383. The bigger motor would respond better to the improved parts as well.
    STILL going to need a chip burned for optimum performance. Go look at thirdgen.org and read up on it. Believe the article by "traxxion" is the one you want. Basically, for the cost of having a chip or two burned, you can get all the equipment you need to make them yourself, short of a laptop.
    Only reason to wait is money. If you can afford to get them now, great. Of course, as soon as you buy something, you'll find a great deal.:)
    I would *speculate* that a motor as you describe would probably be in the 300HP range. Of course, there are a lot of variables, so thats a WAG. Torque is arguably more important when building a truck engine, but it really depends on what you want to do with the truck.
  11. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    Whats your budget for the 350 hop up?
  12. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    You replied to the other guy, but I assume that you were asking me. I really don't have a budget. I'll spend whatever I have to spend to do it right. I was planning to just doing a little now and then going into it more whenever I rebuild the motor, but now I am thinking that I am just gonna do all that I can now without taking the motor out and then I won't have to spend as much when I build it. I would be willing to spend up to $2,000 or $3,000 now. I think that in that range I can get a motor that will give me all the power that I want to have right now.
    I was thinking about...
    1000 to 1200-heads
    400-cam and intake
    400-custom chip
    plus whatever the throttle body will cost
    Am I about right on my numbers?
    Trey
  13. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    You can get your lower end rebuilt and afford good heads and a chip within the $3k budget i'd bet!!
  14. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    I am going to get my lower end built, but I am not going to do it now. I have done so much work to the truck and have still not wheeled it, so I want to wheel it for a while before I take the motor out.
    What do you mean by "afford good heads"? Is the $1200 that I allowed for heads not enough?
    TRey
  15. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That's plenty is what I'm saying. You could probably build yourself a bad ass motor for $3k. Freshen the bottom end with a turned crank, resized rods with good bolts, some good new pistons, new bearings/rings/gaskets and a new cam suited to a truck and a GOOD BALANCE JOB. Then add good heads to that and I bet you're WELL within your $3k budget and you'd have an awesome motor that put out 275-300 HP and ran at any angle or upside down and still would crawl through anything. /forums/images/graemlins/smile.gif
  16. 99firehawk
    Dec 15, 2002
    491
    http://www.sdpc2000.com/cart.asp?action=catalog_start&catid=2172
    SD8060TBIH Vortec Head Kit, TBI Intake, Headers $949.95
    or
    SD8060ATBIH Upgraded Vortec Head Kit, TBI Intake, Headers $1,059.95
    http://www.sdpc2000.com/cart.asp?action=prod_detail&catid=3189&pid=130007
    109.95
    http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=2398&prmenbr=361
    249-CL12-235-2 Grind: 254
    Duration: 210°/218°
    Lift: .447''/.462'' $169.99
    http://store.summitracing.com/default.asp?target=search.asp&type=bykeyword&searchtype=both&part=holley+tbi
    http://www.tbichips.com/catalog/Default.htm
    theses should get ya started.
    gears probaly wouldnt hurt either but, I shouldnt be telling someone else to do it when Im still runnin my 3:08s with my 35s
    good luck
    HLY-502-6 Chevrolet/GMC: 1987-89 5.7L trucks, 670 cfm 2 barrel TBI model 3210 replacement TBI 11-22 $339.95
  17. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Is the intake centerline of 110* suitable for the TBI? I thought we needed at least 112*????
    What is the difference between the '89 and '90 model years of TBI? Why does the Holley replacement say 'to '89'....
    Just curious, sorry about the slight hijack....
  18. MudFlap
    Dec 2, 2002
    250
    Winston-Salem, NC
    Thanks guys
  19. Wally81k5
    Wally81k5 1/2 ton status
    Jul 14, 2002
    139
    Cold Lake Alberta
    I had a 90 with 350 tbi, i blew the motor so the rebuild had flat tops, rv cam, throttle body spacer, underdrive pulleys and single 3" flowmaster.
    It have tons!!!! of nuts.
  20. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I don't know that as fact, but I'd say that's probably a good idea. I'd imagine that a narrower LSA could cause the MAP sensor to go nuts. I'm sure there are ways around this, but for a fairly stock build like yours, I'd just go with a more computer-friendly cam.
