horn blows when turning
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by moose73, Apr 12, 2003.
  1. moose73
    moose73 Registered Member
    Apr 11, 2003
    22
    chatt,tennessee
    when turning the the horn will blow and can here arc under the dash, any suggestions on a fix,not very knowledgeable on electrical
  2. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Hahahaha! NICE!
    That happened for a while in my dad's truck, it would just start honking for no reason.... People would look and we'd just wave at them and smile. HAHAHA! /forums/images/graemlins/rotfl.gif
    I'll bet it's shorting out in the steering column somewhere. If you take off the horn button or the cap on the steering wheel it's probally arc-ing and shorting to ground somewhere in there. Theres a spring that's supposed to hold the cap up so it wont honk until you push on it.
    You can disconnect the horn relay or the wire to the horn to get it to stop honking for a short term fix, but you might have to take off the steering wheel with a puller to be able to track down where the wire is shorting out. /forums/images/graemlins/thumb.gif
  3. amm888
    amm888 1/2 ton status
    Jul 20, 2002
    309
    Woodland Hills, CA
    i once had a honking problem in my camry - got mad, punched the steering wheel, and the horn sounded nonstop - i just pulled the wires off the horn mechanism under the hood - just to get it to stop. might want to do that till you actually fix it.
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    I had the same problem when I replaced the steering wheel. My fix, relocated the horn button. /forums/images/graemlins/thumb.gif
  5. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Theres a metal cup under the center section of the steering wheel. When it makes contact it shorts a circut and makes the horn blow. I've been there.
    Pull the steering wheel cap up and loosen the screws holding the metal cup. Perminate fix jam something under it and leave it. My fix was cutting the horn wires till I replaced the steering wheel with a smaller grant wheel. /forums/images/graemlins/rotfl.gif
    It probely just too tight, i think theres supposed to be a piece plastic under it to act like a spring, if it breaks or gets tighted to much it makes contact (esp when turning) and after a while it stay on (thats when I cut the wires to the horns). /forums/images/graemlins/thumb.gif
  6. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    hahah sorry..i know that doesnt help but that is funny!! /forums/images/graemlins/rotfl.gif
