Horn problems/relay?
Discussion in 'The Garage' started by cochino12, Jul 24, 2004.
  1. cochino12
    cochino12 1/2 ton status
    Dec 23, 2003
    563
    Parker, Co
    I cant seem to get my horn to work. The green wire going to the horns has power constant as well as the wire under the horn button on the steering wheel. I dont think that the wire should have constant power under the hood. I checked my chilton and it shows a horn relay in the wiring diagram, where is the relay? any other ideas?
  2. diesel4me
    Jul 24, 2003
    17,540
    926
    Massachussetts
    The relay is under the dash near the fuse block,in a separate wire harness--it looks like a square directional flasher.I dont think the green wire at the horn should be hot all the time either--the relay might be stuck in the "honk" position,but then the horn should be blowing if it works--tried putting a hot lead to the horn itself to see if it still honks?.The wire in the horn button is a ground wire--so maybe the green wire IS hot all the time /forums/images/graemlins/thinking.gif.Usually all my horn troubles were solved by replacing the horn or the relay(or hooking up a horn button!). /forums/images/graemlins/crazy.gif
  3. cochino12
    Dec 23, 2003
    563
    Parker, Co
    Yeah as soon as I hook up a new horn it honks, that why I'm thinking the relay is stuck. Thanks
  4. dyeager535
    26,975
    Do you feel the "springiness" in the horn button when you depress it?
    Very commmon for PO's to get into the steering wheel and mess that up.
