  1. 85 4x4 shortbed
    85 4x4 shortbed Registered Member
    Apr 7, 2003
    20
    My horn doesnt work.What are some common probs?
  2. RockyRider13
    RockyRider13 1/2 ton status
    Jul 11, 2001
    102
    Kansas
    The cig. lighter can ground out, burning up the fuse, which is the same one for interior lights and horn.
  3. 85 4x4 shortbed
    Apr 7, 2003
    20
    already checked that (i hear a click in a little white box when horn is depresed)
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Maybe checking to see if the horn wires were plugged into the horn itself??????
  5. Txstruck
    Txstruck Registered Member
    May 25, 2002
    87
    Seagoville, Texas
    Some horns go thru relays first. That may be bad. Run a direct wire from horn to battery and see if it honks. /forums/images/graemlins/truck.gif
  6. Muddin_Mavric
    Muddin_Mavric Registered Member
    Jun 28, 2001
    55
    Centeral WI
    the genius that had it before me put the plunger thats inside the stearing wheel in backwards so i had to take it apart and turn that around then it worked fine.
  7. 85 4x4 shortbed
    Apr 7, 2003
    20
    what does the relay look like?
