Horny Problem
Discussion in 'The Garage' started by Chevy305, Nov 5, 2006.
  1. Chevy305
    Chevy305 6 Lug 14bsf Status Premium Member GMOTM Winner
    Jan 23, 2006
    11,230
    488
    New Hampshire
    Even since i bought my truck I have been having problems with the horn. I have gone through 3 actual horns, 2 fuses, cleaned the contacts, and replaced the contacts. My horn will work great for a month or 2 at a time then take a crap on me. I'm not sure why it does this. I have traced all the wires associated with the horn and have come across no problems like shorts or anything like that. Is this just a Chevy truck thing or is it just me?
    This is on a 85 K10
  2. 70GMC
    70GMC Registered Member
    Nov 1, 2006
    40
    Reno, NV
    are the contacts on the turn signal cancelling cam on an 85? i've never messed with one that new before
  3. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    i believe the horn is fused along with a couple other things like your dash lights. check that stuff too.
  4. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
    Actually, I'm not sure the steering collumn is from an 85. So I'm not sure but I believe the contacts are separate from the turn signal cam.
    Also in Chevy trucks, where there any years that did not automatically click off the turn signal after completing a turn? or is that just a worn/broken part in my steering collumn?
  5. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    you've got broken parts inside the column, and the contacts are on the cam.
    most common problem is the springs on the turn signal switch, if that is the case, most GM dealers stock them, and they're only a couple bucks.
  6. goldwing2000
    goldwing2000 Guest
    I've had intermittant horn problems caused by a bad horn relay.
  7. 70GMC
    Nov 1, 2006
    40
    Reno, NV
    nope you definetly need a new cancelling cam, thats the thing that clicks the turn signal off after completing a turn. so like beaterk20 said, the contacts are on the cam and that's most likely the problem
  8. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Sounds familiar to my old horn issues. I just went with an air horn off a Freightliner instead, no more worries. I hated fighting the electric horn. You never find out that it quit working again until it's too late and the time for needing it has passed.:mad:
  9. Chevy305
    Jan 23, 2006
    11,230
    488
    New Hampshire
    Ya my turn signal doesn't click back off after I make a turn. So I guess I need new parts of some type.
  10. onlychevy6
    onlychevy6 1/2 ton status
    Mar 29, 2003
    1,293
    Hockley, Texas
    mine just started to do this. good info. except the bad thing with mine is i have a train horn and when that goes off when you least expect it. :yikes:
