Horrible Drivetrain Grinding Noise
Discussion in 'The Garage' started by AZPiNsTrIpEd, Jun 23, 2006.
  1. AZPiNsTrIpEd
    AZPiNsTrIpEd 1/2 ton status
    Jan 24, 2005
    289
    3/4Tonsville
    Ok this noise is gonna make me go nucking futs:mad: Its a loud grinding noise and it sounds like it's coming from the T-case but i'm not sure. It only happens when I let off the gas in OD not in D. I've replaced all my U-joints front and rear, and still no luck. I even put in zero rates thinkin the extra driveshaft length would help, with no luck. I've read that it could be a loose chain in the T-case or slop in the gears, but I dont think its the rear end. Any one have any other ideas??????
    Oh yeah the truck is:
    350/700/208/10b/14ff w/detroit
  2. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    How much lift are you running? I had this in my truck when it had 12" of lift and every time I let off the gas it would do that. Turns out it was a driveline vib even though it sounded like gears grinding when I let off the gas. When I lowered it to ~4.5" it went away.
    Hope this helps.
  3. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    I had the same issue with my 86 k5 when I put on my 4 inch lift.
    I lowered the t-case 1 inch and it solved the issue.
    the tcase drop is a free mod. If you look at the bolts that hold the crossmember to the frame there are 1 inch spacers above the frame rail. Take out the bolts and put the spacers between the frame and crossmember. Here is a picture of the spacers before I moved them. These 2 were below the crossmember, the 2 on the otherside were above the frame.
    Hope this helps
  4. AZPiNsTrIpEd
    Jan 24, 2005
    289
    3/4Tonsville
    I have 4" suspension and 2" body. I already lowered my t-case about a 1/2 inch but maybe I should lower it some more. Anyone else have this problem?
  5. sarasotausmc
    sarasotausmc 1/2 ton status GMOTM Winner
    Dec 16, 2003
    769
    Jacksonville NC
    I have the exact same problem, changed the ujoints, no help. When I get home, guess I'm lowering the T-case to see if it helps. I've learned to feather the gas just right to lessen the noise on deceleration.
  6. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    I don't know much about lifts. Why would the noise only occur in OD, but not D, if the noise was the T case.? Isn't there some type of one way clutch set up in the OD gearset? I would bet on that going south.
  7. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    i have that exact same problem, i have the 700r with a 6 inch susp lift and 35's and just had 3000 dollars worth of tranny reconditioning and the tranny guys didnt worry about it too much. i asked him and he said it was nothing of concern. that could be just to get my money again later or it could be the truth. its been a few months since and ive just learned to ease the gas to get it to quit.
  8. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    I had the same symptoms with my 208, I posted a few questions but not much help. I also messed around with the crossmember and joints with no luck. The problem persisted........and eventually my T-case cracked completely in half while I was on the freeway going over a bridge, spit my driveshaft in middle of the road.
