Horrible grinding noise from dana 60
Discussion in 'The Garage' started by koldsimer, Mar 20, 2006.
  1. koldsimer
    koldsimer 1/2 ton status GMOTM Winner
    Jan 10, 2005
    1,480
    texas
    Here's what is going on. When in 4h or 4L there is a terrible grinding noise coming from my front axle. It started soon after I put my yukons and detroit in. I have eliminated it being the driveshaft, t-case or the lockouts. The noise seems to come from the differential. I pulled the cover today and the ring and pinion look perfect. There were no shavings in the oil and the carrier bearings looked ok. All the ring gear bolts were tight and the caps were tight as well. The only thing that I can think it may be is the carrier bearings. When I put the detroit on, I though we might have damaged one of the bearings during the removal process. The thing that keeps throwing me is that the noise occurs with each revolution of the tire with no variance. This makes me think that something is rubbing somewhere. I checked the axleshafts and u-joints to make sure they were not grinding against anything. I disassembled the wheels down to the spindle and made sure the wheel bearings and spindle bearings were fine. I cant figure this out and it's driving me crazy. The noise is much less apparent when under load. It's definately louder when just coasting. I dunno. Suggestions please.
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    So you re-used the old carrier bearings? That could be the issue.
  3. koldsimer
    Jan 10, 2005
    1,480
    texas
    I was kinda thinking that also. It just keeps throwing me off though- all the bearing issues i've had in the past in any vehicle seemd to be more of a constant whine or grind. This is totally silent then all of a sudden a bad grind real quick at the same spot every revolution.
  4. readymix
    May 30, 2004
    6,706
    26
    Does it do it with the hubs unlocked?
    In 2WD?
  5. koldsimer
    Jan 10, 2005
    1,480
    texas
    nope, no noise in 2wd at all. I can shift the case into 4wd even with the hubs unlocked and it makes the noise. I can lock the hubs in while the case is in 2wd and it makes the noise.
  6. readymix
    May 30, 2004
    6,706
    26
    Sounds like it is in the carrier then. Time to pull the detroit
  7. tomseviltwin
    tomseviltwin 1/2 ton status
    Dec 23, 2001
    2,065
    Utah
    Is the dustshield on your brakes bent and rubbing?
  8. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    The rotors are always turning....not just in 4wd. :screwy:
  9. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    is the grind more or less when you hammer it in 4wd???
    I have had this grind since 1994 and I still have it.. I do have to figure it out eventually.... maybe soon....
    I replaced the d-shaft... all new bearings, new detroit replacement carrier....
    wondering if it is the np205....... groanin???
    I can be at a redlight in 2wd and drop the clutch BIGTIME and it wont do it.. once I put it in 4wd and punch it from a stop.. it is a constant grinding sound... hard to explain... but if I drive not really hard it doesnt do it.....
    something else I was thinking... how are your tranny mounts? lets say in 4wd you have both shafts spinning and could make the tranny shift side to side.......
    Sorry I am not too sure but a few things to check :crazy:
    I havent worried about mine cuz when something breaks then I know what it is... I know that isnt the way to figure it out but like I said I have had this problem FOREVER and it aint broke yet...
  10. clarkjw24
    clarkjw24 1/2 ton status GMOTM Winner
    Dec 4, 2003
    3,531
    McBee, SC 29101
    Pinion yoke
  11. miniwally
    miniwally 1/2 ton status Premium Member
    Aug 11, 2003
    3,065
    Colorado
    I would take the shafts out of the front, and see if it makes the noise while turning the pinion by hand. If not then the problem is somewhere on the shafts. If it still maes the noise then it is in the diff and you are aleady part way there to getting the thing apart.
  12. koldsimer
    Jan 10, 2005
    1,480
    texas
    Thanks for all the ideas guys. Today i'm gonna pull the shafts and see if it still makes the noise. If it does, i'm gonna pull the carrier and put new bearings on it just to see if that is it. To reply to some of your suggestions- it cant be the pinion yoke because it happens with every revolution of the tire. If it was pinion related I would expect it to grind about 4.5 times for every tire revolution. The noise goes away when the drivetrain has a fair amount of torque in it. The noise is worst when coasting. All tranny/engine mounts are new. The front driveshaft has been taken off and the noise is still there.
  13. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    The first thing I'd check are the lockouts. I'd pull everything related to the hubs out and then drive it.
    How dirty are your axle tubes?
  14. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    He runs flanges.
  15. koldsimer
    Jan 10, 2005
    1,480
    texas
    I've pulled everything but the axleshafts. Axletubes are clean. I've put both the slugs and lockouts in and it still makes the noise.
  16. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I'd put it on jackstands and pull the tires. Rotate the driveshaft and listen. It's probably a bearing cage if it's not the ring gear rubbing on something.
  17. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Could it be the inner rock flange on the stub shaft not being square to the shaft causing it to rub on the knuckle?
    Ira
  18. Leper
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    That sounds like it could be it. Do you still have that on your axles?
  19. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    Go a pm steve...
  20. koldsimer
    Jan 10, 2005
    1,480
    texas
    Good suggestion but definately not it. I watched carefully when turning the axle and it wasn't making contact anywhere. I went ahead and pulled the detroit and the carrier bearings and pinion bearing looked good. What are the chances that these bearings are bad even though they look fine to me?
