HORRIBLE sputtering and stalling when under load...
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Lotsa_Faith, Nov 12, 2002.
  1. Lotsa_Faith
    Lotsa_Faith 1/2 ton status
    Jul 10, 2001
    474
    Mckinney, Texas
    OK took the truck for a 15 mile trip...did fine. NO sputtering, stalling, anything. 4 hours later, start it up and head back home. the ENTIRE way, every time its under a load (going up hill, accelerating), its coughing and sputtering and cutting out. AND it smells strong of raw gas in the cab. What could it be?
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    well it's running very rich it sounds but i'm an EFI guy so i don't know how to fix it sorry. /forums/images/graemlins/frown.gif
  3. Lotsa_Faith
    Jul 10, 2001
    474
    Mckinney, Texas
    Anybody know what to do? I got new plugs and wires tonight, could that help?
  4. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Sounds just like what I am having problems with. Fuel is leaking from the QJet while it sits in the driveway, or while it runs. Causes it to load up and bog, and die repetitively. I had to get the carb filled with fuel, and watch for leaks. Mine is leaking from the drivers side primary bore. I can't determine what is causing it. /forums/images/graemlins/frown.gif I would look into the well plugs, which may be leaking.
    Just my .02!
    -Dan
    BTW - I bought my carb from Edelbrock, and plan to send it back to have them replace or service it.
  5. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Could be a sticking power valve. The old Q-Jet that was on my K30 had this problem. It would run great most of the time but ever once in a while it would hang up and would flood real bad. When I took it apart the power valve had pretty deep wear marks in it.
  6. hammer
    hammer 1/2 ton status
    Aug 29, 2001
    449
    Binghamton N.Y.
    fuel filter clogged
  7. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    im with hammer, aside from the fuel smell. i would put my jimmy on the fuel filter.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
