Horsepower add ons
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zach78k5, Apr 16, 2001.
  1. zach78k5
    zach78k5 1/2 ton status
    May 14, 2000
    406
    i have a 350 with a Qjet carb, edelbrock intake, K&N, headers, dual exhaust, what else can i add on that will help to boost my horse power without sacrificing my mpg atleast, not much. i have seen some of these intakes, but i say a comparison test in off road magazine that put the k&N up with all the other bolt ons. i cant put in a bigger cam or anything internal because it will void the GM 36,000 mile warranty.
    thanks
  2. 72blazer4x4
    72blazer4x4 Registered Member
    Jan 27, 2001
    60
    vacaville ca
    some new heads, vortec or maybe some edelbrock aluminum
    jeremy
  3. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    How about swapping for some lower gears? I don't know what gears you have now, but if you currently have 3.07s and go to 4.11s you'll feel a HUGE difference in power.
    <font color=blue>//////
    <A target="_blank" HREF=http://blazer79.coloradok5.com>http://blazer79.coloradok5.com</A>
    </font color=blue>[​IMG]
  4. nyyef
    nyyef 1/2 ton status
    May 16, 2000
    479
    Saudi Arabia
    you need to put on more miles, so you can change the cam. that will give you the biggest--seat of the pants--difference.
    Knife.
    knife.coloradok5.com
  5. NYC K5
    NYC K5 1/2 ton status
    Apr 3, 2000
    185
    Staten Island NY/da bronx
    get an ignition system. im running the jacobs omni magnum and notice a power increase as well as increased gas milage. i know alot of guys on this site have some stories about jacobs but i have been running it for 2 years 16000 miles and have not had a problem.
  6. zach78k5
    May 14, 2000
    406
    how much did you pay for the jacobs and what does it contain? distributor?
  7. dyeager535
    26,982
    191
    If you can't monkey with the cam, your next step, and only step, that will make a significant increase is gears. Lower (numerically higher) gears will hurt your freeway MPG, but typically won't make a bit of difference in town, maybe even a little increase.
    Some Vortec heads would be a big step in the right direction too, but again, if that comes under warranty invalidation, then you can't do it.
    Dorian
