horsepower arguement
Discussion in 'The Garage' started by jacked_86chevyk10, Jun 22, 2004.
  1. jacked_86chevyk10
    jacked_86chevyk10 Registered Member
    Feb 4, 2004
    42
    SNELLVILLE, GA
    me and my buddy got in a heated arguement about the horsepower my truck has....there is no dyno anywhere close to our houses...(we live out in te georgia boonies) but could anyone give me a guesstiment on all this stuff....87 k10 350 standard bore/stroke...edelbrock alum. intake....hooker long tube headers.. holley 600 cfm (i think)... k&n filter... JUST A GUESSTIMENT WOULD HELP...he thinks around 190 and im thinkin a lil bit more up in the upper 200's, but we're not sure
  2. Wingnutt
    Wingnutt 1/2 ton status
    Feb 20, 2000
    324
    NOVA
    IIRC your K5 had 210 hp toatlly stock. That was with the origional TBI setup. If you haven't freeded up your exhaust flow, your headers ain't doing as much as they are capable of. That Holley IMHO is a step backwards unless it's been tuned specifically for your rig. You may have added about 20 hp if you haven't invreased you exhause flow capabilities; if you have, you may be looking at about 240-250 hp now.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    thats assuming the motor was good to begin with. Oh and a 600 holley isn't a step back if its tuned right. Stock TBI unit flows like 450 CFM.
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I have a GM crate 350 and it has 260 hp with headers, so I think you prolly have quiet a bit more than that since you have aluminum intake and other things like that.My .02
    /forums/images/graemlins/thumb.gif
  5. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    eh don't overestimate the gains. I put a new carb and headers on my K5, I believe it easily added 50+ horsepower with a couple simple bolt ons. Motor is fresh, but the previous carbs were HORRIBLE. If you have a good QJet setup well running well a carb and intake swap I don't think would net you a whole lot.
  6. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    First make sure you're comparing apples to apples. Are you estimating SAE net HP, Gross flywheel HP or Rear Wheel HP?
    Rear wheel it'd likely be under 180 hp, SAE net maybe 230-240 depending on a ton of things...and gross flywheel hp could be 300 or more. All from the same engine.
    Rene
  7. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Probably actually only making around 150 to the ground depending on the what tranny.
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Just tell him horsepower doesn't matter, torque does ( horsepower is torque x rpm / 5252 anyway ) . Then challenge him to take HIS vehicle up the tallest hill you can find that YOU CAN make it up. Should shut him up if he can't or WON'T do it . /forums/images/graemlins/k5.gif
  9. Emmettology 101
    May 9, 2000
    8,126
    FL
    Another thing I haven't seen anyone mention is that if your 87 came with a TBI and no one switched the cam when you went ot a carb, then you'll probably have less. I am going to say your friend is probably close in his HP guesstimation at the crank.
    Find a dyno or maybe someone with a desktop dyno and it will give you a better idea.
  10. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    You're probably right, but I was trying to be nice. Not everyone wants to hear their mighty small block is only making about 150 at the wheels on a good day and if it's tuned well.
    Rene
  11. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    If it's still the original 350 that came equipped with TBI (200-210 factory H.P.), and you simply switched the intake, the Holley carb, and the headers I can't imagine it's making any more than maybe 230??? I just can't see you getting in the "upper 200" range with a couple external bolt-ons.
    If the engine is a previous generation that was originally carb'd from the factory I believe the H.P. rating was only around 160, then the 190 H.P. estimate would probably be pretty close.
  12. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Rene
    [/ QUOTE ] I thought I would be in the upper 100's with my old 350 with some air intake mods and dual exhaust....put it on the dyno and it made 120HP at 3,500-4,500 RPM. That isn't bad actually when GM rated it 175HP at the crank brand new. Heck even my built 406 didn't impress me all that much when it was on the dyno, made 215HP and 300 ft lbs of torque to the ground but that was also with a th700 behind it with an unlocked converter and tall gears.
    My guess is he has a th700 and they are the worst about swallowing power EXPECIALLY with the converter un locked, worse than the big heavy th400...IIRC. /forums/images/graemlins/whistling.gif
  13. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    put a Blown 540" Merlin in it. you will have all the power you need. /forums/images/graemlins/thumb.gif
  14. hi pinion
    hi pinion 3/4 ton status
    Sep 25, 2003
    5,354
    **PLUMBING THE WORLD**
    I am so tired of these stupid little babygame laws here in Ca....... if we diddnt have these laws you would see nuts and bolts flying out from under the damn truck. /forums/images/graemlins/rotfl.gif IF ONLY.......... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
  15. Grim-Reaper
    7,385
    Atlanta
    88 FI 454 Suburban was only rated 230hp stock. /forums/images/graemlins/dunno.gif
    Now it does make 385lb ft of torque at 1600rpm. /forums/images/graemlins/eek.gif
