Hot air stovepipe thing on passenger side...
Discussion in 'The Garage' started by dremu, Nov 20, 2006.
  1. dremu
    Feb 27, 2000
    15,967
    459
    East of San Francisco
    exhaust manifold. 1974 big block (though my SBC of the same vintage also has it.) What's it do, how's it work?
    The tin around the exhaust manifold is, well, falling off something fierce ... I could fix it, or I could just remove all of it (no smog on this old a truck) if it doesn't do much.
    Is it only for cold starts, or ...? Never gets below freezing here in California at sea level, so I donno how much good it's doing, blowing hot air into the intake, right?
    -- A
  2. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    It takes warm air off of the manifold for the engine. there is a flapper inside the snorkle of the air cleaner that when cold pulls air from the manifold and when warm it pulls it through the snorkle deal. Depending on the year of your vehicle (i.e for smog) you have to have that or it will fail visual.
    Ira
  3. prerunner1982
    prerunner1982 1/2 ton status
    Nov 4, 2002
    235
    Oklahoma
    sandawgk5 beat me to it...
  4. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    mine crumbled off of the k5 about a week after i bought it. never replaced it. and i've been driving my pickup around for most of a decade without one. never had a driveablility or inspection issue because of it. they are getting tight on emissions, here in dfw, but i'm sure it's still much tighter in california.
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    Being that you are in cali and its pre smog id ditch it.
  6. dremu
    Feb 27, 2000
    15,967
    459
    Yup, through '75 is smog exempt, so I don't need it for that ... only question is does it do anything useful, i.e. should I fix/replace the tin, leave the pipe hanging down off the aircleaner (maybe hoseclamp it in place?) or don't even bother with the downpipe?
    -- A
  7. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I wouldn't worry about it, brother. It's only a necessity in areas where there's a possibility of low temperatures and humidity that together can cause your carb to ice up during a cold start. It *may* help your motor warm up a wee bit faster, but other than that it serves no real purpose in your neck of the woods.
  8. dremu
    Feb 27, 2000
    15,967
    459
    Cool; thanks. One less thing I gotta deal with during the motor swap.
    -- A
  9. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    I replaced mine...like $2 for the little slinky pipe thingy at the parts store...and yeah on really cold mornings around here it helps it warm up faster but it's not like you really need it for that.
    It will fail the visual inspection around here if you don't have it though.
    -Avery
