Hot/cold heater...HELP!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by lehtola, Mar 30, 2001.
  1. lehtola
    lehtola 1/2 ton status
    Mar 21, 2001
    192
    North Carolina
    I noticed over the last week-end that when I used my heater...it was blowing cold then hot then cold again. I don't think my thermostat is sticking and the engine temp is normal. What could this indicate?
    1990 GMC Jimmy 350/TH700R4/NP241/10 bolts, 4" skyjacker lift, 35x12.50R15 BFG All Terrains on 15x10 AR Baja's, Flowmasters.
  2. could be a clogged heater core. try flushing it out- you could take care of some cats at the same time-LOL. also make sure its not the thermostate. it could be stuck open. cheep and easy to replace. also- and this sounds really stupid, which means it's happened to me- make sure your coolent isn't low. if its really low-it's happened to me- it wont even make it to the heater core. good luck
    78, 350/350/203, 3/4 ton, 4" lift, 35" BFGs
    <A target="_blank" HREF=http://bluebeast.coloradok5.com/>http://bluebeast.coloradok5.com/</A>
  3. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    My guess is that you are low on coolant. Does it get cold wen you stop and then hot when you get moving again? This happens because at idle your water pump cant force much coolant into the heater core when not full of coolant. That is why when your truck overheats at idle sometimes it does no good to trun on the heater. Its just blowing air through an empty heater core.
    When all else fails... Check the blinker fluid.
    78 K-5
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Another vote for low coolant. Check the radiator and make sure it's full.
  5. freeforever
    freeforever 1/2 ton status
    Feb 21, 2001
    305
    Missoula, MT
    I had the same proble...low collant...I filled it and no proble....but you better check your radiator for a leak! Mine had one so I used Leake fixer stuff
    "Fool me once shame on you...fool me twice shame on me"
    "A closed mouth gathers no foot."
  6. lehtola
    Mar 21, 2001
    192
    North Carolina
    O.K. Thanks everyone...it was the low coolant. But now I think I have a leak.
