hot cranking
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87project, Jul 17, 2002.
  1. 87project
    87project Registered Member
    Jul 9, 2002
    98
    Alabama
    Here's the problem,87 305 TBI,cold crank, turn key fires up,hot crank,fuel pump kicks on,turns won't fire,cools off,fires up.Just replaced plugs,wires,cap,and rotor button,i'm lost. thanks for any replies in advance /forums/images/icons/crazy.gif /forums/images/icons/mad.gif
  2. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    could be heat sink, where the wired get hot and electrical stuff gets hot so the resistance in everything goes through the roof. if you have headers make sure you have a heat shield on the starter.
  3. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    Make sure you have your starter heat shield, and all exhaust heat shields in place, there is one above the cat. converter, and muffler. Your engine bay will run cooler if you remove all the insulation on the underside of your hood, it will shed heat much faster. I did this and put in a 180 degree thermostat and my engine runs at 180-190 /forums/images/icons/cool.gif
