Hot exhaust pipes under passenger and drivers seat?
Discussion in 'The Injection Section' started by FWP, Nov 5, 2006.
  1. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Anyone have this problem with a TBI swap? It only happens when under high power for 30 minutes or more- i.e. highway driving with 42's and a 7000 lb pig:D
    Engine temp is normal, the tranny gets a little warm as I would expect. Stock puter, mild cam. It's been this way ever since the swap, starting with 37's, 38.5's then 42's. Stock manifolds, if that makes a difference.
    Ideas? Thoughts?
  2. sweetk30
    Nov 1, 2004
    25,544
    540
    horseheads , ny 14845
    what cam and do you have the specs? you might need a custom chip if its off from stock a bit to far.
  3. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    An engine running too rich or too lean can make the exhaust pretty hot.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    With my dual exhaust & TPI I get hotspots under the seats and under the footwell for the rear passenger area. I still have carpet even for now:D. When I loose the carpet I imagine the problem will just get worse.
    I am going to get a good 3" exhaust system built for the truck though which I am hoping will help the problem some and keep the exhaust a little further away from the floorpan.
    Harley
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Harley , I got it too , but I assume in our case its the cats getting the hot . You have two , I have one . My hottest spot is just above the cat which sticks about 4 inches rearward of the heat shield .
  6. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    i would guess the cat is the reason also, if you have a stock chip and a mild cam you are going to let a lot of unburned gas into the exaust causing the cat to get really hot, there are a few ways to solve this, one you should really get a chip to make the truck run the best it can, you could also cut the cat out but then your truck is still not running the best. I would suggest getting a chip and go from there
