Hot Hubs.....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by det45, Apr 2, 2001.
  1. det45
    det45 1/2 ton status
    May 23, 2000
    112
    San Antonio Texas
    Quick Question.....My Warn Hubs on my 89 K5 are warm but not real hot after I drive it around for a while. Is this normal? They were installed correctly with the proper grease and the wheels rotate freely when warm/hot. All this is happening with hubs un-locked with normal driving........Thanks......Det45
    One Fine 89.....
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    It sounds like heat induced from your brake rotors. I wouldn't worry too much about it.
    "My blazer may be slow, but it goes faster at higher speeds"
    Jim
  3. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    have you taken your hubs off lately????? The grease could've got containmenated and the bearings could be going to hell. I'd check it out quick.
    Doug Krebs
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    It's normal for the hubs to be warm to the touch after a long drive. If they're too hot to touch, then it's time to investigate what's going on. (Or quit leaving your foot resting on the brake pedal while driving!) [​IMG]
  5. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    Hrm? On evry car I have ever driven the lug nuts get really hot when it has been driven. Evry time you hit the brakes ALOT of heat is created. Since your hubs are connected to your roter they will get hot. If you drive for a long time or in stop and go traffic they will get too hot to hold your hand on for more than a couple of seconds. If you ask me... nothing to wory about.
    Sparky
    When all else fails... Check the blinker fluid.
    78 K-5
  6. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    If you're on the brakes a lot then they'll certainly get hot. But if you're just out cruising they shouldn't be too hot to touch.
    Up on Pikes Peak they have a ranger hut in the middle of the road, about half way down, where they check your brake temperature. If they're too hot, they make you stop and let them cool off. Last summer I was coming down in the Suburban, following a minivan from one of the flat states. [​IMG] He had his brake lights on all the way down.
    When we got to the hut, the ranger pointed one of those infrared thermometers at his front wheel and made him park for a while. I asked what the temp had been on the minivan's brakes... Over 600 degrees F! Mine were 104. [​IMG]
