Hot Pumkins!
Discussion in 'The Garage' started by southernspeed, Aug 8, 2006.
  1. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I ran my rebuilt axles for their first decent run today and after 80 miles of constant 70mph the rear diff cover and housing was hot to the touch. You could touch it but not keep your hand on there for long.
    How hot do they normally get? This is a 12blt with GL5 80/90 lube.
  2. dontoe
    May 7, 2004
    9,070
    Hickory, N.C.
    I remember reading that 140 degrees F, can cause minor burns.........so it must be less than that.
    Ya have a temp probe for cooking? Stick it in the gear oil..............:wink1:
  3. mrk5
    Apr 20, 2004
    12,331
    1,039
    Northern Colorado
    In the steam plant we would have contests to see how much heat we could stand. 150° seemed to be the temp where we couldn't stand to hang on more than a second or two.
    Four Wheeler or 4Wheel & Offroad did a big article on diff temps. Their stock Sterling 10.25 rear axle in an F-250 with dino oil ran 170° in an unloaded mixed 50-isH mile loop. Switching to synthetic fluid dropped that temp 15-25°(they tried 2 types). The Mag-Hytech cover(3 quarts add'l cap) and the cooler of the 2 synthetics got the temp down to 125° IIRC. Pretty dramatic difference if you're going to be towing.
    We're talking Farenhiet by the way Mark. :wink1:
  4. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    What's that in Kelvins? :haha:
    For the conversionally impaired:
    140f = 60C
    170f = 76.7C
    125f = 51.7C
  5. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    or
    333K
    349.7K
    324.7K
    respectively
  6. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    I would say keep a close eye on it. I have had diffs do that on the first run (well only a couple). If it stays that temp then you should be fine but if it starts to get hotter something went wrong. You may want to pull the cover and double check your backlash and generally look things over. Some weird things can go wrong with new diffs even if you did everything right
  7. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    OK thanks everyone. Kind of puts my mind at rest a bit. I'll pull the cover anyway.
    As I have the pinion up at 6* I put a bit extra oil in but it doesn't cover the pinion bearings as such. Are they ok with a splash feed? I know there is a kind of tunnel in the casing that directs oil to the bearing. I'd read that it's not a good idea to overfill them. Opinions anyone??
  8. blazinzuk
    Dec 20, 2002
    17,412
    3,799
    In some diffs I have done pointing them up to much has caused lack of lube to the pinion bearings, feel up there when you are checking your diff temp if there is alot of differential than it is probably starving them. If not then you are good. The only problem I have had with overfilling a diff is some of the oil came out the breather
