hot start problem
Discussion in 'The Garage' started by GMC500, Sep 30, 2006.
  1. GMC500
    GMC500 1/2 ton status
    Aug 19, 2005
    203
    Safwa
    hi all
    I have a problem starting my rig after driving it for a while
    I've already did the remote solenoid thing, checked the alternator, starter , recharged the battery and replaced the cables from the battery to starter and from battery to the alternator
    the car will start fine when cold
    but when warm it will hardly crank (for a second or 2 seconds ) then it will die
    I don't think it is a timing issue because advancing or retarding the timing ( by turning the distributer) won't make any difference
    what should I look after ?
    thanks for your time
  2. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    My crystal ball went into the shop yesterday so you're gonna have to tell me what vehicle & engine you're talking about.
    but it sure sounds like vapor locked fuel line
  3. GMC500
    Aug 19, 2005
    203
    Safwa
    1986 GMC k10
    355 sbc ( compression around 9.5:1 )
    vortec heads
    RPM air-gap intake
    comp cams Xtreme 4x4 cam
    750 cfm edelbrock 1407 carb
    sm465 + np205 + stock 1/2 tons
  4. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    Ohhh and I shoulda read your 1st post closer......It won't crank when hot.
    Did you check and clean your grounds?
    temperature is creating high resistance or an open somewhere.......
  5. GMC500
    Aug 19, 2005
    203
    Safwa
    I have a new ground cable going to the alternator
    and one to the core support then to the frame
    shouldn't than be enough ?
  6. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    yes probably. what did you mean by you did the solenoid thing already?
    were the windings tested? I don't beleive bench testing a starter with one of those ****ty parts store testers can reproduce or diagnose a hot start failure. but a no load free run test would tell you some other things. but you need to know the RPM its spining at. and what voltage.
    Honestly what I'd do is get another starter reman with return warantee or maybe a buddy has one or whatever and put it in. find out if it still does it. if it does just return the starter. But I'd bet a new starter fixes it.
  7. GMC500
    Aug 19, 2005
    203
    Safwa
    something like this
    I'll try to find another starter to test it
    thanks
  8. GMC500
    Aug 19, 2005
    203
    Safwa
  9. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    Does your rig have the factory heat shield around the starter? They usually get left off after the first starter change. I had the same problem with a 70 Burb with headers. Found a heat shield for the starter, put foil back insulation tween the shield and the starter, and no more problems.:D
  10. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Is Mark Hamilton (MAD Electrical) still in biz?
  11. GMC500
    Aug 19, 2005
    203
    Safwa
    no
    I have replaced the starter and now it is starting fine
    the old one was shot
    thanks
