hot start problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kumma, Feb 7, 2002.
  1. kumma
    kumma 1/2 ton status
    Oct 29, 2000
    380
    Novi, Michigan
    Ok im having problems with starting the jimmy after its been running for a while. 87 350 TBI, After an hour of driving and i shut it off, then try to start 5 minutes later it cranks over but wont fire. It runs extremly hot. I have used starting fluid and it starts right up and runs fine. Is my fuel pump going out? or what?
    <a target="_blank" href=http://www.plymouthscreenprinting.com>www.plymouthscreenprinting.com</a>
  2. possum
    possum Registered Member
    Jan 9, 2002
    72
    NC
    I had that problem for a while. Mine was the choke. The metal vacuum line was kinked where it had a 90* bend in it from the factory. I opened it up and it worked fine. Maybe when you're spraying the starter fluid you're opening up the choke enough to start it. Now I am by no means a mechanic but I had that problem and that is what my problem was. Try that first. It was a free fix, just required a little squeezing of some pliers. Hope it helps.
    <a target="_blank" href=http://community.webshots.com/user/possum1970>78 K5</a>
    we're not always who we are
  3. tRustyK5
    Jul 23, 2000
    36,184
    1,388
    E-town baby!
    You need a carb to have a choke...[​IMG]
    Maybe low fuel pressure combined with the heat soak is causing a vapor lock? I'm pretty sure the fuel pressure should be between 10 and 13 PSI for the TBI. Are there any fuel lines routed near exhaust or anything?
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  4. kpanza
    kpanza 1/2 ton status
    Dec 8, 2000
    1,579
    Lake Forest, Orange County, California
    Yeah, sounds like you're having vapor lock problems...like Rene said, check your lines to make sure they are not too close to headers, etc...you might also want to check the pressure you're putting out. Why is it running so hot? I'd say fix the "hot engine" problem first, then you will also solve the hard starting problems I think...
  5. kumma
    Oct 29, 2000
    380
    Novi, Michigan
    The fuel lines run on the opposite frame rail as the exhaust, they turn up to the engine about 8 inches away from the exhaust pipe. I wouldnt think they're to close. I dont have a fuel pressure guage. Is it possible for the line to vapor lock from heat in the engine compartment? I did notice the rad cap is defective, it hisses when i squeeze the radiator upper hose.
    Craig
  6. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    Vapor lock is just when the fuel evaporates before it gets to the TBI. Any extreme heat can do this to a gas line. Of course the radiator cap should be replaced regardless of whether that is the problem or not. Like the others said make sure the gas line is routed away from the exhaust especially if you have added in an extra peice of rubber line for a fuel filter or what not like many people do. If its a solid line and any area is in doubt try insulating it somehow or seperate it from the hottest are with a heat shield.
    Definately a pavement pounder...with the caveman clutch
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
  7. possum
    Jan 9, 2002
    72
    NC
    OK, you got me one that one.[​IMG] Guess I didn't read it too well. Well, at least my disclaimer about not being a mechanic was in there[​IMG]. Didn't notice he had one of those new fangled jobbies.
