Hot starter question
Discussion in 'The Garage' started by mercercadet, Jan 4, 2003.
  1. mercercadet
    mercercadet 1/2 ton status
    Apr 19, 2002
    216
    Georgia
    Hey all,
    got a problem with my starter on my 350 in my jeep. It gets really hot after I crank it up and takes like 30 mins to cool afterward /forums/images/graemlins/angryfire.gif. it does have a set of aftermarket headers on it. I was wondering if ya'll might have any suggestions?
    thanks
  2. ChevyDrivnRdneck
    ChevyDrivnRdneck 1/2 ton status
    Nov 25, 2002
    714
    Modesto, Ca
    heat wrap and maybe a heat shield. They should have both at just about any parts store. /forums/images/graemlins/thumb.gif
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    If you're not able to re-start your truck after running it...the best thing to do is get a remote-solenoid setup for your starter. The heat created by the exhaust...in combination with the aftermarket headers - probably locating that heat closer to the starter...is not allowing your starter solenoid to operate until it cools down. A remote solenoid located in the engine bay will get rid of this problem.
    Wait, now...just re-read your post. Is it getting excessively hot just by the cranking over of your engine...or is it like I said above (where you experience this only after driving a while) /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
  4. boots
    boots 1/2 ton status
    Nov 3, 2002
    183
    Foothills of CA (Mariposa)
  5. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I made my own heat sheild out of some tin to see if that was my problem and it seemed to take care of it.
  6. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    heavy 4x4 is right. thats what i did for mine. also used a coffee can to make a heatshield. all you need is some snips and a can opener for vent holes.
    nathan
    69K5
