hot starting prob.
Discussion in 'The Garage' started by blazinjimmy, Jul 17, 2006.
  1. blazinjimmy
    blazinjimmy Registered Member
    Aug 28, 2003
    53
    Here's my prob.: Truck starts perfect when cold. But When hot, needs 20 min to cool down, before it'll start. I've put a new starter on it[had it taken off and re-checked]......2 selanoids[sp]..grounded battery & engine directly to frame...all help/suggestions would be appreciated.............thanks.
  2. noahrob
    noahrob 1/2 ton status Author
    Nov 26, 2005
    1,878
    Santa Barbara
    Remote solenoid away from the exhaust...Look in the tech section. Ping me if you can't find it.
  3. ascuro
    ascuro Registered Member
    Sep 19, 2005
    62
    SoCal
    If your headers/exhaust pipes run real close to your starter, they may be heating it up too much. If that's the case, you won't hear any cranking at all when it's hot (but all other electrical will be working just fine).
  4. blazinjimmy
    Aug 28, 2003
    53
    Yes, my truck doesnt crank at all when hot....so maybe I'll have to run a remote solenoid?, I dont run headers, but will see exactly how close my exhaust manifold is to my starter. Thanks for the suggestions....I looked in the tech section-couldnt find the area of reference-help!
  5. richheezee
    richheezee 1/2 ton status
    Dec 29, 2003
    116
    San Jose CA
  6. blazinjimmy
    Aug 28, 2003
    53
    Cool.....thanks much for the info/diagram!! Hope this will solve my starting woes. [The solenoid pictured looks like the same as the one in the '84 diesel Jimmy I used to own-had to replace it twice!]
  7. 3 on the tree
    3 on the tree 1/2 ton status
    Oct 16, 2004
    3,970
    gunnison colorado
    I had the same problem with a header equipped Burb years ago. The factory heat shield was missing. I located another, and wrapped it with high heat insulation-problem solved.:D
  8. diesel4me
    Jul 24, 2003
    17,568
    943
    Massachussetts
    yup--too hot!..
    The starter can "heat soak",and it wont even click if it gets hot enough!--you need a heat sheild over the solenoid,and I've found that painting the starter with aluminum paint helps it reflect the heat off of it some...
    I had one friends truck that did this every time you'd shut it off,and let it sit a few minites(like when you go for a burger ,etc)and it would refuse to start!--even jump starting it would not make the starter crank--but 10 minutes later it would crank over like nothing was wrong again!..
    I ended up putting heavy gauge battery cables,extra ground cables,and a bunch of other work into it that didn't help much...then a stock car racer guy made him a heat sheild out of a hunk of chrome stovepipe ,and tack welded it to his header pipes on the starter side,and it never acted up again!! (chrome reflects the heat better than plain bare metal will)...the guy said his race car did the same thing after every race,until he added the sheild..:crazy:
  9. blazinjimmy
    Aug 28, 2003
    53
    This sounds exactly like my problem......maybe I'll try a heat sheild/wrap first....its a pain in the a$$ having to wait 10-20 min. eveytime I turn my rig off...............thanks for the input!
