Hot Vs. Cold Plugs - Advice Needed
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1986Blazer, Oct 30, 2001.
  1. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    I just replaced the plugs on my 86 350. I used AC Delco R43TS (gap .043). The manual calls for R45Ts (gap .045). What is the performance difference. Has anyone used both of these and if so what is the difference? Thanks for letting me know.
    <a target="_blank" href=http://www.geocities.com/keywestk5/KeyWestK5.html>http://www.geocities.com/keywestk5/KeyWestK5.html</a>
    So I says to him, I said, "get your own monkey."
    1986 K5, 350 GM Crate, 700R4, NP208
  2. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i do not think there would be a noticable performance gain at all. Just make sure they are the right ones for your application [​IMG] I would use factory specs to gap them unless you have a mildly warm'd over engine or aftermarket heads. I gap mine @ .045 and it runs fine
    -Zakk
    '77 K5 SB 400 TH350 NP203 p/t 6" Lift D60 14BFF 4.10's 36"Wrangler II's
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    See above. I couldn't agree more. Unless you have detonation problems, use the stock heat range plugs.
    Tim
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Could someone explain the whole heat range thing to me. I have wondered about this for a while. How does it work, and what is best for an MSD ignition system? I had a buddy with a 600+HP BBC and he had to run plugs that were 3 steps cooler form stock. Does it all depend on what the engine like? Is it a trial and error thing? Thanks
    Harley
    My Chevy isn't broken, its just out of gas.
  5. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    Heat range is just a measure of how fast the plug can dissipate heat. "Colder" plugs dissipate the heat quicker. This can help eliminate mild pinging problems, whereas fouling can be reduced by going to a "hotter" plug. "Hotter" plugs won't make more spark or give you any more HP.
    Like has been said, in most cases, stock is best.
    Still Poundin' "pavment" after all these years!!! [​IMG]
  6. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I run plugs 4 steps colder in the firebird when I race on nitrous. I cant use them on the street because they foul to quickly. Trust me I already tried because I got sick of switch them out every friday. No as for performance gain, there is no performance gain. I have run stock heat range plugs on motor, and then the ones 4 steps colder. I ran .05 seconds quicker in the 1/4 mile with the colder plugs. If you can feel that 1 horsepower then go for it. But be ready to switch the plugs out more ofter because they like to foul out quickly.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  7. Zepplin
    Zepplin 1/2 ton status
    Aug 29, 2000
    920
    Bay City, MI 48706
    Check it out:
    http://community.webshots.com/user/zepplin1976
  8. BIGRIG
    BIGRIG 1/2 ton status
    Feb 29, 2000
    488
    Independence, MO
    hey that is one sweet site all kinds of info..plus I 'm more of a picture guy anyway! ;)
    MY DRINKING TEAM HAS A FOUR WHEELING PROBLEM![​IMG]
