Hotwire a K5? Wife has all the keys at work
Discussion in 'The Garage' started by Sample, Aug 14, 2003.
  1. Sample
    Sample 1/2 ton status
    Oct 15, 2002
    536
    Apache Junction, AZ
    Can someone tell me how I can get my '83 K5 started without keys? My wife took both sets of keys with her to work and I need to get to work.
  2. Calclips
    Calclips 1/2 ton status
    Apr 4, 2001
    1,005
    Swartz Creek, Michigan/Flint while in school
    I don't know, not in the truck stealing biz...
    TTT anyways.
  3. dyeager535
    26,979
    Gotta remove the steering wheel, and figure out how to keep the locking "pin" disengaged...if it pops up when you are driving, your more than likely gonna crash. I believe the transmission shifter is also "locked out" without the key, at least for those of you with automatics.
    You can always run a lead straight from the battery to the distributor, jump the starter terminals with a screwdriver, and be done with that part. But getting around the column issues, without destroying it, or spending hours trying, isn't going to be easy.
    This is why to effectively protect a GM vehicle with this style column, (cars or trucks) you need to shield the column where the key is.
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Jumping started solenoid with a screwdriver, wire to distributor as mentioned but the steering column will take you probably as long as it would take your wife to get home. Fords are nice cause the solenoid is on teh fender so you never have to climb under it, helps when you don't want to be conspicuous in stealing a vehicle. Not from personal experience just happen to know. /forums/images/graemlins/grin.gif Of course if you want to damage the steering column crow bar that locking setup out and grab the pliers and go.... But that won't end well when its time to fix it.
  5. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Now is the time when you wish you had a first-gen. Dash ignition=no locking wheel /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif. Good luck.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    My question is, why does your wife have keys to your truck at all? That's a far worse problem than not being able to get to work!
