Houston heat 100
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by trogdor4x4, Aug 4, 2004.
  1. trogdor4x4
    trogdor4x4 Registered Member
    Dec 15, 2003
    37
    Spring, TX
    Does anyone have any suggestions on what I can do about my AC. The temperature warms up from 72 to 78-80 at stop lights and stop and go traffic. While I am going the temp of the air hitting the driver is 72 and inside the vent is 58. It doesn't sound light at big difference (72-78) but it is the difference between sweating and not while coming home from work.
    I had thought about changing crank pulley size to a larger one, but I didn't know if it would mess things up and I didn't know where to get one nor did I know what size to actually get.
    I also thought putting an electrical fan blowing into the core (by the grille).
    Are there any other suggestions? yes do one of these or no, don't do those?
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    I put a small electric fan in front of my radiator and it comes on when I am at a stop light and it seemed to help alot, also you may want to switch to dual electric fans since they pull more air than the stock fan.
