How 4x4 works?
Discussion in 'The Garage' started by palomares, Sep 8, 2004.
  1. palomares
    palomares Newbie
    Aug 19, 2003
    Culiacan, Sinaloa, Mexico
    I have blazer k5 1986, but I don´t Know how use 4x4. Somebody can help me.
  2. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    get out, and turn these all the way to the right
    (the gold part in the center)
    get in, put the truck in neutral, then shift the floor shifter into 4 wheel drive high or low, then put the truck in gear and go
  3. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    yeah like Branndon said, go to the front axle of the truck, turn the little bar on in the hub (the part that sticks out from where the tire/rim is mounted.
    then hop in your rig, and look at the transfercase shifter (the smaller of the 2 shifters, if you have an auto, and move it down to 4hi or 4lo
  4. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    welcome palomares /forums/images/graemlins/waytogo.gif Hang around long enough here and you won't be able
    to recognize your truck in a year /forums/images/graemlins/waytogo.gif
  5. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    If it is a stock 86 it doesn't have manual hubs.. Just put it in 4wd drive and go.. Back it up 50 feet or so in 2wd to disincage..
  6. palomares
    palomares Newbie
    Aug 19, 2003
    Thanks everyone, it´s works. /forums/images/graemlins/smile.gif
  7. CaveBlazin
    CaveBlazin 1/2 ton status Premium Member
    May 21, 2002
    1,348
    Middle TN
    My 86 came stock with manual locking hubs and I am sure that it had the stock axle up front before I changed it to 3/4 ton. So maybe some 86's had manual and auto locking hubs. /forums/images/graemlins/dunno.gif
  8. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Nope.. they all came from the factory with auto hubs.. Somebody put the manual hub in afterwards..
  9. dyeager535
    26,979
    You POSITIVE on that?
    Not trying to start anything, just interested to know for sure.
    I know in '85-86 the parts manual shows the *D60* with auto or manual hubs, but 87-88 shows only manuals for D60. Guess they figured out they were a bad design. /forums/images/graemlins/smile.gif
    Interested to know about the manual hubs, since IIRC all the 10 bolts have the right snap ring grooves for both auto or manual, and that would seem pointless if they didn't use manual hubs.
    Or was this only a Blazer thing, where a 3/4 ton the same vintage COULD have had manual hubs?
  10. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    I am 99% positive that all 1/2 tons came with auto hubs. and about 99% positive all 3/4 tons came with auto hubs.. I do not now for sure on the 1 ton's
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    How are the snap ring grooves for manuals and autos any different?
    My '60 came from the factory with manual hubs and I have never personally seen a '60 with factory auto hubs although it's possible that they were available.
    All mid 80s trucks came from the factory with auto hubs.
    I was going to mention this earlier but I thought we were simply talking about K5s which are all 1/2 tons and all of those years would have factory auto hubs.
  12. dyeager535
    26,979
    I thought there was an "outer" and an "inner" snap ring groove, one of which is used with auto's, one without? I thought at one time there was some question as to whether you could put manual (factory) hubs on certain axles that came originally with auto hubs. Could be mistaken, I just seem to remember that from a long time ago.
    If they used the same grooves, my mistake, no biggie, just seems odd that auto hubs (that sucked so bad) were the norm in a truck that still ran wing windows, didn't have a digital radio available, AC was optional in, and so on. Seems like a luxury item more than manual hubs, but then again, maybe it cost GM no more money to throw the crummy auto hubs on the truck.
    I could almost see it as a warranty issue, but if you took it out of 4wd but didn't back up, you'd still run with the hubs locked all the time. Guess maybe GM could have figured that people would remember to back up more than they would remember to get out and unlock them. /forums/images/graemlins/confused.gif
    Service manual shows a different 205 for the auto hubs as well. One other reason to stop using both hubs at the same time, GM eliminated another transfer case.
  13. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Yeah, two of the 60's I had came with auto locking hubs /forums/images/graemlins/dunno.gif
  14. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    My 85 K5 came factory with manual locking hubs. Says so in the glove box on the options sticker. They are GM deluxe hubs (warn standards)
    Harley
  15. CaveBlazin
    May 21, 2002
    1,348
    Middle TN
    Harley
    Yeah mine says the same thing in the glove box..
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Can I see a picture of them? I've never seen a set of auto hubs on a GM 60.
    I'll stand corrected on the 1/2 ton thing, although I've never seen a stock mid-80s 1/2 ton with factory manuals.
  17. dyeager535
    26,979
    Do CUCV's count? /forums/images/graemlins/smile.gif
