how about a 10 bolt (on an 89) disk brakes???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by solowookie, Aug 2, 2001.
  1. solowookie
    solowookie 1/2 ton status
    Mar 31, 2001
    3,880
    Wyoming
    I've seen write up's on both the 14B and the 12B, but nothing on the 10B for disk breaks??? anybody know if somebody makes something for this application???
    [​IMG] <font color=blue> Jeff </font color=blue> [​IMG]
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Stainless Steel Brakes and a few others make a 10 bolt disk kit. Apparently, the rear disk setup off of a 99-up Silverado is a direct bolt-on too.
    Generic Signature
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    hey, that could be some really good info to know!!! I'll have to check it out and see if this is cheaper then doing the kit from SS! [​IMG]
  4. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>TSM makes the brackets, your parts store has the front rotors and the junkyard has some 80-85 eldo calipers. Add flexhoses and some caliper pins and your done.</font color=blue>
  5. solowookie
    Mar 31, 2001
    3,880
    Wyoming
    I'm gonna have to put this on my list of to-do's cuz I like the disk's on my other k5 too well[​IMG]
  6. RESTORE89
    RESTORE89 1/2 ton status
    Jan 31, 2001
    548
    CHAS SC
    could you take the whole rear end from a 99 up silverado and swap out an 89, and what would you have to do with the proportioning valve if anything
    It needs a bigger motor.
    what's in it now?
    doen't matter it NEEDS A BIGGER MOTOR
    89 350tbi/700r4h/np208/4.11's
  7. Pugsley
    Jan 16, 2001
    3,556
    Tucson, Arizona
    That's exactly what I was thinking - I've been watching the boneyards for one, and haven't seen one yet. According to my local brake guru, the proportioning valve shouldn't need changed, only the lines and e-brake cables. Spring pads would need relocated, but that's quick and simple. I'd really like to get my hands on one and see if it works, since I could probably use a new rear-end anyway.
    Generic Signature
  8. TheGeneral
    TheGeneral 1/2 ton status
    Feb 22, 2001
    556
    NC, USA
    I have a 10 bolt I did with the TSM kit about 3 years ago. All went well, although I had to go to the yard to exchange caddy e-brake calipers twice. Couldn't be rebuilt. No problems with operation over the years. Hindsight being what it is, I would just make the brackets and use standard front rotors instead of spending the $ for the TSM kit. Just my .02 $ worth.
    If you ain't hurt, you ain't playin' hard enough.
    The General
