How about dash lights?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Capman2k, Oct 9, 2001.
  1. Capman2k
    Capman2k 3/4 ton status
    Jun 22, 2001
    5,070
    dg
    I guess I'll try some do-it-yourself work :D
    How would I go about replacing my dash lights so I can see how fast I'm going without straining my eyes?? easy? tough? ??
    Don't want to end up like the Buick I had....
    79 K5 <a target="_blank" href=http://www.geocities.com/capman2k/>Go Here</a>
    Wyoming doesn't exist, the map maker just needed to fill the space above Colorado[​IMG]
  2. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Cakewalk[​IMG] Take the gauge bezel off, and then pull the gauge panel itself - give everything a good cleaning and put in all new bulbs.
    Of the 5 toughest dogs in the neighborhood, my cat's ranked #3
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  3. Itali83
    Itali83 1/2 ton status
    Feb 12, 2001
    795
    Westbrook Maine
    You can acualy reach almost all of the bulb sockets if you stick your arm up behind the dash. Pugs has a better idea if you really want to clean it all up and do it right, but if you are pressed for time, search around and you'll find what you are looking for.
    Ben 87 Jimmy
  4. xplosuv
    xplosuv 1/2 ton status
    Mar 9, 2001
    515
    Sacramento, CA
    Hey there,
    Yes pull your gagues, very easy. Then go to your local Honda rice race shop and get the Hyper White bulbs for your dash. Most of the 70's and early 80's that I know of use a push in type bulb, " W-4 " bulb. these hyper white bulbs are much brighter and are true white, not the dingy yellow stock ones. I belive theres 7 bulbs to replace.I replaced the bulbs in my 75 with red ones. Im putting purple ones in my 76, just a cool little mod. If you cant find them, Let me know and I can sell you them. as I have them in stock at my shop.
    -Tony
    If you cant go over it...GO THROUGH IT !!! <a target="_blank" href=http://www.CaliforniaK5Krawlers.com>www.CaliforniaK5Krawlers.com</a>
    75 Jimmy 11" lift with 40's
  5. dyeager535
    26,975
    If you ahve any problems with your mod, please let us know. There are two different types of lights for the dash ("dim" and "bright") that you can buy anywhere, but my concern with going to the brighter bulbs is heat. They "burn" hotter, and I'm not sure that the sockets/printed circuit board/gauge housing can withstand the heat of them. I'm sure it the difference would take months or years to notice if anything was going to happen though.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  6. Capman2k
    Jun 22, 2001
    5,070
    dg
    Those colored ones sound cool :) I don't think I can find any around here... how much do you sell em for and what colors?
  7. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    What's the deal w/ the 2 types... brighter and dimmer? You have any part numbers for the brighter ones... like a wagner replacement bulb #? I never knew there were 2 types. I'd love the super bright ones but am also very concerned w/ the heat.
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  8. dyeager535
    26,975
    Check your email : )
    BTW, the Sylvania number is 2825. Didn't verify that myself, so you may want to check that out by buying one bulb first.
    Changing the post...I was only partially informed..here's the rundown:
    stock 194 - 2 candlepower
    168 - 3
    2825 - 5
    (Sylvania part #'s)
    2825 seems like way too much for me, but hey, to each his own. Guess you could try them for awhile, if they are cheap enough. Then the dimmer might actually be useful! : )
    Dorian
    My tech/links page: &lt;a target="_blank" href=http://www.dorianyeager.com/index2.html&gt;http://www.dorianyeager.com/index2.html&lt;/a&gt;
    No anti-theft measures on your truck? No pity when its stolen<P ID="edit"><FONT class="small">Edited by dyeager535 on 10/10/01 11:26 PM.</FONT></P>
  9. dyeager535
    26,975
    BTT.
    Got an email from a guy: (car, same dash light setup)
    "Damn right I do! I used the 5w bulbs and it might have fried a wire on my
    old 1979 wiring. According to cough cough knowledgeable sources my 1979
    wiring might not be as adequate as the 83+ wiring so I have to find the
    burnt wire to get my dash lights working. Even the lights by the radio have
    gone out."
    FWIW
    Dorian
