How about no front swaybar?
Discussion in 'The Garage' started by jess, Mar 22, 2004.
  1. jess
    jess Registered Member
    Jan 4, 2004
    27
    CT
    How sloppy will my truck be with no sway bar and a 4 inch lift? Truck won't be a daily driver so I can handle some lean if it saves me on installing new bushings and a disconnect kit. Just don't want driving to be a constant pucker factor.
  2. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    I removed mine a while back when I had stiff Procomp springs, I had since changed to softer BDS springs. I noticed no difference with either set of springs. IMHO all the sway bar does it cut down on front flex, take it off, you won't regret it /forums/images/graemlins/thumb.gif
  3. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Just unbolt it from the U-bolt plates and drive it and see for your self... If you have stiff springs its not bad at all
  4. samiam
    samiam Registered Member
    May 17, 2003
    42
    Turned mine into a boat anchor about a year ago, never missed it.
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Don't worry about it. I ran no swaybar on 2.5" lift (soft springs) and now on my 4.5" lift. The 2.5" was a little sloppier then I would have liked but with the 4.5" I have no problems even as a DD.
  6. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    I got rid of mine 5 years ago...best 23 lb's I've ever chucked IMO.
    Rene
  7. jess
    Jan 4, 2004
    27
    CT
    Rene
    /forums/images/graemlins/thumb.gif That's what I figured. Good, one less piece of undercarriage to scrape and paint.
  8. Storm Trooper
    Nov 24, 2000
    4,640
    I dumped mine a year or so ago and can't hardly tell. I have 4" tough country easy rides and it works great. I think you really only need it in a power turn situation.
    Save weight and hassel.....dump it.
    Now to hi-jack....hehe
    What could we use them for?
    A chin up bar?
    Extra large horse shoe?
    Roll bar for a go-cart?
    Sorry.......I had to do it. /forums/images/graemlins/grin.gif
  9. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Boomerang for a tough guy...
    Rene
  10. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I took mine off about 2 years ago. Never missed it since. I notice it when the top is on (hasn't been on for 18 months now) I had tough contry 4" springs and now 4" BDS, no problems for a daily driver. Best mod I ever made, also the worst being I replace the bushings in it 2 months before I ditched it /forums/images/graemlins/doah.gif
    Just try it you'll like it.
    (same will be said about a sawzall in a few weeks my friend /forums/images/graemlins/deal.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif)
  11. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    I just hooked mine back up the other day, and i love the way it drives now, i had it disconnected when i did my front axle swap,(new ball joints,8 lug conversion,4.10 gears) it was quite weird, swayed alot, especially in curves and even worse in those curves with a decent bump in them. Even driving straight, the truck would sway side to side and got real bad when i hit bumps. I didn't like the way it drove, but i loved the way it flexed when wheelin. I have decided to go ahead with the sway bar disco's. Much nicer ride with it connected, but also sucks now that it is connected when wheelin.
    BTW, mine is a Burb, that may have something to do with it, alittle bigger ass, may sway a bit more than a Blazer.
